Question about Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
Softener dispenser does not empt - Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer
Fabric softener is still in dispenser after wash
Check for clogged water nozzles in the dispenser. Also, it's advisable to check for a gummed up softener dispenser--softener has a nasty habit of drying out and leaving a thick waxy paste on everything. Check the dispenser where you put in the softener--I recommend CUTTING THE SOFTENER 50/50 WITH HOT WATER to keep it very fluid. Softener causes lint! Be a scrooge when it comes to adding softener--enough to make the clothes smell nice and be soft--BUT THAT'S IT!! On rare occasions, one of the electric inlet water valves might be malfunctioning and not letting water flow to the softener dispenser.
NOTE TO EVERYONE!!!==>ON ALL *HE* WASHERS, NO MORE THAN 2 TABLESPOONS OF LIQUID DETERGENT IN ANY LOAD, IT'S PLENTY!! You're only using 1/3 of the water the old style washers used to use. As for softener, use only enough to get the job done--and always cut it with hot water, especially in the winter.
Aug 19, 2015 | Washing Machines
Electrolux 1292 softener compartment not dispensing after few years
Good Morning Sandie,
I understand that you are having trouble with the softener dispenser not dispensing on your Electrolux washer. I suggest running a System-clean cycle on your washer, as well as taking out the dispenser drawer and taking the dispenser compartments out and cleaning them. It might be that the softener has built up inside the dispenser drawer. If that does not work, reset your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. If you are still noticing the softener not dispensing, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
May 09, 2014 | Electrolux Washing Machines
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
After normal run liquid soap remains in soap dispenser. Not empting soap dispenser properly.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Mar 22, 2011 | Dishwashers
Fabric softener dispenser not working
If the model number you have this listed under is correct, you should have the softener dispenser on the center post of the agitator. If this is the case, you need to remove it by popping it off the center post and take it apart. Soak it in some hot water to dissolve the softener residue and reassemble. Most dispenser related problems are attributed to softener that hardens and clogs up the dispenser. Liquid softener is essentially a wax and will do this over time. You will need to clean it from time to time.
Apr 26, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Softener Doesn't Dispense
either valve is broken plugged or allined wrong. Think the latter is the case
May 14, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Fabric softener will not dispense
water remaining in the dispenser is normal doesn't mean its not dispensing consult your owners manuel
Jan 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Samsung 3.5 cu. ft. High Efficiency VRT Front Load Washer Logo
12 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
