Question about Crosman C11 CO2 BB Gun - 0.177 Caliber
My 1077 co2 crossman gun leaks all c02 out when you put hole in co2 cartridge
SOURCE: Crossman 1204 nightstalker
Try with this:
http://www.network54.com/Forum/275684/message/1136858902/nightstalker+research+pics+%28long%29
Regards.
ACA.
Posted on Feb 10, 2009
  • 6 Answers
SOURCE: After inserting and compressing the CO2 cartridge, the CO2 leaks
You need to check the rubber o-ring seals both in the plug and there could be another up in the gun where the cartridge end meets the inside. If you have a broken o-ring you should be able to find one that fits at your local hardware store or store that sells air rifles. Hope this helps.
Posted on Jul 12, 2009
  • 86 Answers
SOURCE: A SOON AS I POT THE CO2 IN MY CROSMAN 357 GUN
the gasket on the gun is probably bad
Posted on Jul 29, 2009
EngineerMC
  • 185 Answers
SOURCE: Have a crossman 1077 airgun but when I put in the
I would send it of to fix, playing with compressed gas is dangerous, sound like a seal my have corroded.
Posted on Feb 13, 2010
  • 58 Answers
SOURCE: I have a Crossman airgun Crosman 357 CO2 Pellet
Click here for the parts list and exploded view diagram showing internal schematic:
http://www.crosman.com/pdf/manuals/C357%20EVP%20&%20PL2.pdf
And here's the owner's manual:
http://www.crosman.com/pdf/manuals/crosman/357/C357-OM1.pdf
Best of luck!
Posted on Jan 14, 2011
I have a Crossman 1077 air gun that leaks co2 when I install need to get it fixed
They are not repaired, sorry been there done that with two of them. Never leave a charged CO2 cart installed, it blows out the seal.
Jul 12, 2017 | Optics
How to fix the leak on my c02 .22 air rifle
There is a tiny spanner nut over the tiny "O" ring seal for the CO2 cartridge. You must find a tool to remove that, it is pinned in there and it will likely break when you try to remove it, if so sorry but the gun is then just so much junk.
Aug 19, 2016 | The Optics
I have an older Crossman BB gun marked "Crossman
Time to buy a new model. I had 2 of those with similar problems and couldn't find parts. Try the CO2 model 1088. I'm happy with mine. Spray the seals with silicone spray monthly or every 2 cartridges.
Sep 10, 2011 | Air Tools & Compressors
Have a crossman 1077 airgun but when I put in the CO2 cartrige it empties the gas. Used very little. Is there a home remidy or send it out to fix.
Feb 13, 2010 | Crosman (4032)
Jul 12, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crossman mark 2 is leaking gas...everywhere
Check out www.mac1.com. Tim is one of the best airgun tuners around and can fix and/or improve your gun.
Nov 18, 2008 | Optics
Bb gun trouble
Could possibly be simply the time it takes to pierce the seal until it actually seats itself on the gasket. I usually wind up the screw until it is ready to puncture the seal and then I wind up for a quick twist in order to make it seat quicker.
Aug 19, 2008 | Optics
Crossman Mark 1 CO2 Pellet Gun
Check out www.mac1.com. Tim can sell you the o-rings or customize your gun to another level (see the LD pistol).
Steve
Jul 22, 2008 | Optics
Put together
1 Chrome Rail (for attachment to Worktop)
4 Self-Tapping Screws (to attach chrome rail)
1 CO2 Cylinder Support Stand
1 CO2 Cylinder (empty)
1 CO2 Regulator (high/low pressure gauges)
1 CO2 Air Line Hose (red)
2 CO2 Air Line Hose Connectors (black)
1 Beer Keg Coupler
1 Beer Tower Unit (complete with faucet, hose and wing nut)
1 Rubber Washer (to be installed inside wing nut)
1 Beer Tower (Quick Connect) Bayonet Attachment (beer tower installation)
4 Machine Screws (to attach bayonet to beer tower)
1 Gasket (beer tower base)
1 Pull Handle (beer tower faucet)
1 Beer Keg Stand (required for 30 liter keg installations only)
1 Protective Plate (refrigerator cabinet floor)
2 Cantilever Wire Shelves (conversion to all refrigerator application)
1 Chill 'n Tap Exterior Cabinet Plug (located on worktop)
1 CO2 Air Line Hose Plug (located exterior rear cabinet)
1 Plastic Drip Tray (2 piece)
1. Remove Worktop: Using a Phillips Screwdriver, remove the
three screws located on the front underside edge of the
worktop and the three screws located at the rear (back)
side of the worktop.
See Fig's. 1 & 2
Remove the worktop from the cabinet and position the
worktop on top of the cabinet so that the front corners
are staggered across the front corners of the cabinet.
2. Installation of Top Rail: Attach the chrome rail to the work
top using four self-tapping screws from the underside of the
worktop through the pre-drilled holes. (attach the front ends
of the rail first)
3. Re-Install Wo r k t o p : Install the front of the worktop onto the
cabinet, then lower the rear side of the worktop over the
backside of the cabinet. Secure using the same screws
removed earlier. (the smaller screws at the front the larger
screws at the rear)
4. Installation of CO2 Cylinder Support: Install the cylinder
support onto the four studs located on the exterior back
wall of the cabinet. (no tools required) Align the holes in
the cylinder support with the studs and push down firmly.
See Fig. 3
5.
Installation of CO2 Cylinder: Install your " fully charged"
CO2 cylinder into the support stand. IMPORTANT NOTICE:
ALWAYS EXERCISE EXTREME CAUTION WHEN
HANDLING PRESSURIZED C02 CYLINDERS:
6. Installation of C02 Regulator:
Attach the CO2 Regulator to
the C02 cylinder by screwing the regulator nut onto cylinder
valve and tighten (snug) using an adjustable wrench.
7. Installation of C02 Air Line Hose to Regulator: Attach one
end of the (red) air line hose to the hose barb connection
on the CO2 regulator. Secure hose by using one of the two
(self locking) black plastic snap on clamps provided.
(use pliers to snap the clamp tight to assure that there are
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
CHI
See Fig's. 1 & 2
of the rail first)
screws at the rear)
See Fig. 3
5. Installation of CO2 Cylinder: Install your " fully charged"
6. Installation of C02 Regulator: Attach the CO2 Regulator to
no leaks)
See Fig. 5
Fig. 1
Fig. 2
Fig. 3
Fig. 4
Fig. 5
LL'N TAP ACCESSORIES (included with this unit)
Jan 07, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Crosman C11 CO2 BB Gun - 0.177 Caliber Logo
Top Crosman Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Crosman Tool and Hardware - Other Expert? Answer questions, earn points and help others
