Question about DeLonghi EC702
Delonghi EC702 as soon as I start to make espresso, the ready light turns off and it's not made hot enough
SOURCE: Describe your DeLonghi BAR 32 Espresso
many of them having DeLonghi BAR 32 Espresso is suffering from the same problem it cannot be solved it is this model's drawback
Posted on May 15, 2008
  • 2039 Answers
SOURCE: how do i clean the pump for the delonghi ec702?
you have t use a discaller for expresso machine not vinergar not strong enought follow the instruction on the discaller put product inthe machine with the water start the the machine after a few second turn it off for 10 minute time for the discaller to work repeat untill empty rinse very good that it do that every 3 month thanks pierre
Posted on Dec 13, 2008
SOURCE: Delonghi Espresso Maker Issue
check the water temp and make sure the grind is not to fine. if both of these checkout ok then it may be a weak pump. you will have to find a replacement pump.
Posted on May 05, 2009
SOURCE: DeLonghi EC140 Espresso filter
Why is the coffee not flowing aas fast and why is the crema not consistant?
Posted on Jul 09, 2009
  • 5 Answers
SOURCE: I have a Delonghi espresso
Check your operating manual for decalcification. do not use vinegar you may demage the machine
you can order the product to clean and decalcifi
good luck
Posted on Aug 25, 2011
Steam is not strong on my ec702 delonghi. I have cleaned the wands. The wand spits out a lot of water with a strong steam, bu the steam gets weaker as I am trying to froth.
The steam temperature control (Thermostat) is not functioning.
The small quantity you get at the start is the steam pressure build up with hot water. Water steam cannot keep up the pressure.
Replace the steam thermostat.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Dec 24, 2016 | DeLonghi Coffee Makers & Espresso Machines
Ec702 delongi is not pumping for espressor but steamer works
first perform a chemical cleaning, place the chemical in the water tank and then this hot place to make coffee, so that the chemical clean pump and piping hot water, repeat this until you spend all the water,
if not repaired you may have problem with the water pump, solenoid or inlay is great need to remove the tubes and clean them out
ramon
nomarpartsupply.com
Sep 01, 2014 | DeLonghi EC701 Espresso Machine
How do we open the delonghi ec702?
Once the milk frother jug is removed, there's a little catch, pull this gently towards you and it will open the unit.
May 12, 2014 | DeLonghi EAM3500 Espresso Machine/Coffee...
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Espresso shots pour very slow for both the single and double shots.
Did you try adjusting the group head screw? And/or cleaning and checking the valve in the group head? Good visuals and instructions here: https://myprojectsandmods.wordpress.com/2014/10/27/delonghi-ec702-espresso-machine-no-water-flow-fix/
Feb 03, 2014 | DeLonghi EC702
My EC702 is very slow at making shots
were you able to fix this issue? I am having the same problem.
Oct 26, 2013 | DeLonghi EC702
Won't heat up
nosolo, i descaled my machine with water and vinegar do you think i damaged my machine? I can't even get it to pump water, when i turn my machine on, it's silent, how do i descaled it again?
May 22, 2013 | DeLonghi EC702
How do i clean the pump for the delonghi ec702?
Dec 13, 2008 | DeLonghi EC701 Espresso Machine
Delonghi BC0255 steam output
The contact number for Delonghi should be 1 (800) 322-3848.
Apr 08, 2008 | Espressione Cafe Roma Deluxe 1329
DeLonghi EC702 Logo
108 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Paul Bade
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
