Question about RCA HD61LPW165 61" Projection HDTV
Lubricate dlp color wheel
Rca scenium hd50lpw175 color wheel its makes a whirling noise and its cuts off
  • 103 Answers
SOURCE: rca scenium 61 inch dlp
the unit has a bad color wheel,a big pain in the ass to change.the part runs about 175.00 labor is about 200.Try first to get the manufacture to fix unit,be persistant
Posted on Mar 22, 2007
Slinteriors
  • 8617 Answers
SOURCE: RCA HDLP 50W151 scenium color wheel
They make two different color wheels for the Rca DLP are you positive you got the right one. As usually its a straight forward install no adjusting needed. Post the chassis number off the back of your set and I will try to help you out with it.
Posted on Apr 07, 2008
waynejamescm
  • 67 Answers
SOURCE: Color is wrong after color wheel replacement
You probably replaced a bearing colorwheel, and it was replaced with a bearingless. If you look inside the TV on the back of the light engine (the silver box in front of and to the left of the color wheel), there should be a jumper (that connects two wires coming out) toward the bottom of it in a recessed little hole. That jumper should be removed if the color wheel was replaced with the air bearing type. Just grasp it gently with a pair of needle nose pliers, and pull it out slowly.
This should restore a normal color operation, but there might be some other adjustments that need to be made if it doesn't clear it up completely.
I hope this helps you...
Posted on Jan 22, 2009
ladywinn
  • 5138 Answers
SOURCE: rca 50" dlp tv makes squeeling noise when turned on.
Color Wheel.
Posted on Feb 20, 2009
Slinteriors
  • 8617 Answers
SOURCE: need a color wheel for RCA Scenium HD50LPW165 50
that color wheel has been discontinued by RCA. Its the 267888 color wheel. You can get your color wheel rebuilt at the following link under color wheels.
http://servicemanuals.vstore.ca/
Posted on Oct 16, 2009
How do I install color wheel in rca scenium HD50LPW175
Try you tube on line to see if they have a video on it
Feb 24, 2016 | RCA Televison & Video
I have an RCA Scenium HD DLP 50" TV Rear
What is the Model Number that is printed on back of TV?
You say TV is DLP ,but you are posting Model# HD52W59 that is for Projection that has 3 Tubes Red/Green/Blue Tubes.
If TV is DLP then problem will be the Color Wheel
If it is Projection then it has a coil on the deflection board that either needs to be replaced or
resolder ciol and take a Glue gun and glue over the top of coil. Coil LL037 on the right handside of the FBT flyback transfomer.
Jan 13, 2011 | RCA HD52W59 HDTV Projection Television
62" RCA dlp loses color
If you hear any winding, whirling or screeching noise (Color Wheel symptoms)
If there is any vibrations in the TV (Color Wheel symptoms) you would need to change the color wheel.
Apr 15, 2010 | RCA HD61LPW165 61" Projection HDTV
I have a RCA Scenium HDTV DLP that has a whinning sound and no picture. Could this be the bulb?
No, this is the color wheel. I have a tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which explains in detail how to change the color wheel and where to get the parts.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 06, 2010 | RCA Scenium M50WH187 50" HDTV
My RCA Scenium HDLP50W151 TV makes is making a loud whining sound that varies in degree. I have picture and sound but the noise is beginning to drown out the TV volume
All projection TVs for RCA are DLP TVs, with that in mind these TVs have a lamp inside that produces white light. The color wheel is the one in charge of giving color to that light. Regularly the color wheel last between 2 to 5 years depending on the daily tv use. Most of the time when the central barring of the wheel is loose, unstable, or out of place it will cause the edge of the wheel to make contact with the housing, producing that whining, whirling, screeching or hissing sound. These sounds can either produce just a annoying sound when watching tv or can cause the tv to shut off. When this happens you’ll have to replace it, if you want to know where to buy, you can look in ebay, there are many parts you can get at very good bargains, the only thing is that you buy at a high risk of the part not working ( I had a bad experience). The other option is to buy at an electronics store online dedicated at selling tv parts, some can help you trouble shoot your problem and others may have tech support over the phone (personal recommendation: Discount-Merchant.com ). And last remember to search your part by part number, NOT by model number, two TVs with same model numbers but assembled on different dates ( different generation TVs ) will have none compatible tv parts inside, so be very carful.
Dec 24, 2009 | RCA Televison & Video
I have a rca scenium hdtv dlp - it won't come on
Bad Color Wheel call Encompass Parts 1-800-638-3328
Nov 12, 2009 | Televison & Video
The humming noise on my rca scenium starts just a
If this is a DLP set, which I suspect it is....you need a new color wheel. Common problem for these sets. If you don't have an extended service plan, about a 300--400 fix, in home.
Oct 09, 2009 | RCA Scenium HD65W20 65" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Ramdon color changes
color in a dlp is controled by the color wheel.. this may be an indication of a pending color wheel failure. is the produceing a lound whining noise. this could be other problems but this is my first instinct on the symptoms given
Jun 13, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD61LPW165 61" Projection HDTV Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
