Question about Rowenta Rs-dc0038 Steam Cleaner 3 Piece Pole Set
Rowenta RS-DC0038 Steam Cleaner 3 Piece Pole Set
5 Suggested Answers
jaylex
  • 417 Answers
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
Posted on Feb 11, 2008
brnspncr
  • 67 Answers
SOURCE: MY rowenta Iron wont produce steam. IT heats up
Sounds like the Steam control valve is blocked or not opening. try cleaning the iron with a kit from wallmart or similar store. Failing that :It may be cheaper to buy a new one from wallmart or similar store.
Posted on Aug 04, 2009
DiYerTech
  • 70 Answers
SOURCE: I would like to send
I have had excellent service from the Rowenta Service Center for this half of the country:
California Electric Service in Concord CA (it is the only Rowenta repair station in California). Go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Posted on Jun 13, 2010
  • 3289 Answers
SOURCE: Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Posted on Nov 07, 2013
Testimonial: "Thanks Steve for your quick response to my problem. I've spent the past few hours calling around to different Rowenta Service Centers and was told by all that the CD0084 replacement pole set is no longer available anywhere. Rowenta Customer support confirmed this as well. Terri"
Rowenta superpress DG 050 leaks water while steaming all over garment. Do I need to Descale the unit?
I've had the same problem with two Rowenta irons. When set to a lower temperature, the iron has a bad habit of leaking water when the steam option is on. I have to either turn up the temperature setting or shut off the steam option.
Feb 28, 2015 | Rowenta Irons
Nov 07, 2013 | Rowenta Irons
Does red light suppose to flash
follow this section troubleshooting and fix it. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Oct 15, 2013 | Rowenta Effective DX1900 Iron with Auto...
Only the green light lights up, dz9080 rowenta advancer iron
A small amount of White vinegar or some diluted dishwasher scale cleaner (calgon) added to the steam water then run it on steam setting ironing some waste fabric untill spotless.
Aug 01, 2010 | Rowenta DZ9080 Iron with Auto Shut-off
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
Iron spits out rusty water. The iron is a Rowenta
Fill it with a mix of 50% white vinegar and 50% water. Let it set for 30 minutes and steam it out for about 2 minutes. Unplug it and dump it. After it cools colpletely, fill it with water and steam it out. The rust is coming from your water supply, not the iron.
Oct 06, 2009 | Rowenta Irons
Cleaning the bottom of my rowenta irom.
Wad up a large piece of wax paper, turn off your steam and "iron" the ball of wax paper. The gunk comes right off the iron and sticks to the wax paper.
Jul 13, 2008 | Rowenta Perfect Iron
Thanks J
Feb 10, 2008 | Rowenta Steam 'n Press DA75 Iron
Rowenta Rs-dc0038 Steam Cleaner 3 Piece Pole Set Logo
Top Rowenta Irons Experts
Joseph Hoffmann
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
