Question about Miele Ovens
I need to replace the glass tray (it broke) for a miele speed oven model H4084. Where can I buy one?
SOURCE: top oven front glass broken want replacement
WHERE CAN WE BUY REPLACEMENT GLASS FOR AN OVEN
Posted on Oct 08, 2008
SOURCE: Door Face needed (Glass broke, model discontinued, can't get part)
Linda, if you can't find a replacement door at local used appliance repair shops - check the Yellow Pages - look to see how the door comes apart.  It is probably held together with 6 or 8 Philips screws.  Get the door apart and take out the broken glass.  Call around to see if an appliance repair store has an oven they are discarding that has the same size glass or larger.  If the glass is too big, phone a few glass shops to see if they can 'cut' it down for you.  Some tempered glasses can be cut and sanded down to the precise size you need. Take your old broken glass to the shop to be used as a template. You should be able to get away with this type of repair for $50 if you compare prices. Cheers, Pavel
Posted on Oct 21, 2008
ginko
  • 19396 Answers
SOURCE: broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
SOURCE: PROB WITH DIPLOMAT 620 DOOR- HINGES BROKE- DOOR
How can I replace the hinges of a Frigidaire FGB24T3A Gas Single Oven ?
Posted on Mar 31, 2010
jyackle5
  • 8197 Answers
SOURCE: I need to replace my
Try calling maly at (800) 999-1360 to get your part.
Posted on Nov 22, 2010
The black tinted outer glass of my univa stove broke in pieces, can you replace it or make another glass the same?
Go to appliancepros.com and put in your model number and look up the glass. They will give you the price. I know on most models u can order the glass without buying the whole door.
Apr 23, 2014 | Maytag Ovens
Missing part
More than likely you will have to contact the company and order it from them. They have a parts order service. Miele.com
Mar 22, 2014 | Miele H4042BM Oven
Replacement for inner glass
Replace the entire door, do not try to straighten it. If you or the retailer paid someone to deliver it, they are responsible for replacing it. The retailer where you bought the oven should be able to replace the door for you or you can contact Miele's Service and Repair Support at
Jan 14, 2014 | Miele DG163 Electric Single Oven
How is the glass cover removed to change globe in a miele oven
unplug the oven, grab cover and turn anti clockwise, sometimes the glass welds itself to its holder and will break, may have to replace this aswell.
Apr 07, 2010 | Miele DG 4080 Stainless Steel Electric...
I broke the glass outside on the door of my Zanussi oven ZOB 646 QX model. The price of this glass together with the panal costs about 1/2 of the oven price. Can I replace this glass without buying the...
In my experience of repairing ovens, it is usually possible to replace glass without going to the expense of replacing whole panel.
Check with the manufacture.
Hop this helps.
Dec 05, 2009 | Zanussi ZHQ575 Electric Double Oven
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
CHANGE THE LIGHT IN MIELE OVEN
Had the same problem. Ended up removing interior oven panels (sides first then top on model H310B). This is easier than you might think. Could then get a good grip on the light's glass cover and it unscrewed easily.
Nov 19, 2008 | Miele DG 4080 Stainless Steel Electric...
Oct 21, 2008 | Amana AOCS3040 Electric Single Oven
Top oven front glass broken want replacement
Dec 10, 2007 | Zanussi ZHQ575 Electric Double Oven
Ovens Logo
76 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
