Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Displays reads dr1 and remote wont respond - Toshiba RD-XS35 DVD Recorder/HDD Recorder
Rotozip dr1 internal schematic diagram
The second one goes near the cord and holds the tool in place.
Aug 10, 2012 | BITS Rotozip Dr1 6 Amp Drywall Router...
I have a DR1 (100 series) and plugged it in to a speed control module. It sputtered afew seconds then stopped working. ...
it most likely damaged the brushes and armature in the motor. some units are not designed to be run at low rpm
Feb 12, 2011 | BITS Rotozip Dr1 6 Amp Drywall Router...
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Mar 22, 2010 | Onkyo TX-DS595 Receiver
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
3. Update the remote.
That should get the remote working again. :)
Oct 31, 2009 | Logitech Harmony 550 Remote Advanced...
Certain buttons wont respond
I had a Sony remote that got dropped. Looked inside and found the circuit board broken. The ideal solution is to by a direct replacement--expensive. I had an amplifier remote with learning and lots of buttons. The cheapest ($10-$15) is to buy a universal remote, hopefully with a learning function in case you need to get more that just the numbers, volume, mute, and up/down. They may not know how to change source, TV/VCR, menu, etc. Most will know how to do Sony while many will not know off brands. -Ken
Aug 29, 2009 | Sony RM-Y173 Remote Control
Toshiba RD 85-DT dr-2 error code
Hold the easy nav button and the number 2 down for a few seconds then try using the remote.Hope this works for you too.
Nov 28, 2008 | Toshiba D-R2 DVD Recorder
Remote control
turn on the dvd player
press and hold the 'enter' key and the '1' key at the same time
remote will start to work again
Sep 14, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Air conditioner
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Jan 01, 2008 | Heating & Cooling
Remote problem
flip open the door on the remote and press setup and 1 at the same time . this will switch it back to DR-1
Oct 05, 2007 | Toshiba D-R2 DVD Recorder
'F' displaying on screen and remote not responding.
Excavated with Google from Philips website: " When a letter F appears on the right hand corner of the screen it means the television is in factory mode. To exit from factory mode, press the 'VOLUME -' and ?CHANNEL -? buttons on the TV set simultaneous for 5 seconds. " Hope this helps Michael Junge
Aug 04, 2007 | Philips 42PF5521D 42 in. HD-Ready Plasma...
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
