Question about Pioneer Cld-v840 Both Side-play Karaoke Laserdisc Ld Cd Player W/ Movies
How to fix my laserdisc player no disc problem
Laser disc not spinning
I'm using a LG5530A and I can't play cds anymore. It keeps on saying No Disc, though there's a disc inside
it could be that the laser that reads the disc is faulty or it could just need a clean.try putting a laserdisc cleaner through it.
if you dont have one then you can try and open it and use a very soft cotton bud and just rub it very gently across the laser.
do not push down on the laser or touch it with you fingers.
you just need to gently wipe it clean.
do not put anything on the cotton bud just use it dry.
let me know how you get on.
Nov 24, 2016 | Televison & Video
Manually eject disc
Wow, great device kudos on it still working. As for the eject - look for a pinhole which you can insert a paperclip into if it is a tray loader.
Apr 11, 2014 | Magnavox Vc8040gy01 Laser Disc Player 1985
Manually eject laserdisc
take a screwdriver, open it up and have a look. Ask it gently.
CD Player does not turn
how long have you been using this player and when did this begin?
Remove the disc and try another. If the player refuses to eject the disc, remove it from the wall and fix it back and fix it back again. Then turn the player on.
If the player still gets stuck on "loading" mode for other disc, then it means the laser is weak.
The lens is weak such that it cannot load data on discs. Its spinning, trying to load, but can't because of the weak laser.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all discs again.
Regards.
Jan 10, 2012 | Panasonic RX-D15 Cassette/CD Boombox
Pioneer CLD-95 only spins laserdiscs when it feels like it
It sounds like the read head assembly is not resetting back to the starting point so it can start off reading the "A" side of the next disc. Probably turning it off and then on resets it back to the start of the "A" side. You might try flipping the disc manually to the "B" side, let it go and then try another disc to see if it works.
Mar 30, 2010 | Televison & Video
Doesn't play any dvd or cd
you need to see if the disc is spinning inside the unit, if it is then you need to either clean the laser with a clean cotton tip or replace the laser, if the disc doesnt spin, it may be the spindle motor(held within laser assy,which is easier to replace) or it could be the mpeg printed circuit board. Good luck.
Sep 26, 2009 | Durabrand DUR7 Portable DVD Player
No power available to Pioneer CLD-D505 laserdisc player
Check the power supply look for anything that might be burnt or damaged.
Feb 10, 2009 | Electronics - Others
UUURRRG
Not spinning disc
If it spins with a little help from yourself replace the spindle motor with improved motor, part number: RXQ0749A
Unable to detect discs
The laser head was the culprit. Replacing it fixed the problem. (Laser head code GRP6278A)
Difficulty reading cd, if it does read the sound is strange and sticks
Replace C101 (1000uF/16v)
Nov 24, 2007 | Philips DVD750VR DVD Player/VCR
Permenant "Unknown Disk"
Try cleaning the player with a DVD lens cleaner.
If you're adventurous enough, and the player is out of warranty, you might want to open up the player exposing the lens part. Then, try to eject and close the disk tray and see if the laser diode lits up (avoid staring at the laser light, it will ruin your eyesight! View it from the side not directly into your eye.)
Also check if the spindle spins a little. Or, with the top cover open (this magnetized cover serves to hold the disc firmly as it spins), insert a disc into the tray and close it. See if the spindle spins with the disc.
This problem points most of the time with either a bad laser or misalignment. If misalignment is the case, this could be fixed by carefully turning (very slowly...) a tiny potentiometer located near the laser diode (experiment with the best setting, mark each turn and try any disc with each turn. Be patient)
This fix is not for the faint of heart, and at your own risk. If you're not sure of what you will be doing, leave the servicing to a qualified technician.
Sep 30, 2007 | Alba DVD55 DVD Player
Toshiba d-r4su won't finalize
to clear "error 14", press the "display" button on the remote control - this has worked every time my toshiba has an error 14 message
Sep 14, 2007 | Toshiba DR4 DVD Recorder
Pioneer Cld-v840 Both Side-play Karaoke Laserdisc Ld Cd Player W/ Movies Logo
70 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
