Question about IBM Infoprint 1532 Laser Printer
Infoprint wrinkling paper
This printer suddenly jams and wrinkles paper
SOURCE: IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Posted on Apr 17, 2009
NitrusInc
  • 326 Answers
SOURCE: Infoprint 1634 repeatedly jams
It may be time to replace the Fuser.
There is no certified way to repair a Fuser with purchasable parts, the assembly it self must be replaced.
Posted on May 22, 2009
SOURCE: paper tray is in the printer,but the printer says missing tray 1
There are two possible solutions: The first is that the lugs on the side of the paper tray are broken, and the printer cannot "see" a paper tray. In this case you need a new paper tray. The other possibility is that the tray and paper size sensor inside the printer is faulty. Often just pushing the contacts can free them, and sometimes the metal prongs that sense the lugs on the side of the paper tray get unseated. Just use your finger to reseat them correctly. If that doesn't work, the sensor board is likely to have failed, and will need replacing
Posted on Jul 17, 2009
  • 32 Answers
SOURCE: IBM Infoprint 1532
There is probably a small piece of paper in the back of the printer in the fuser. Shutdown the printer and wait a few minutes as this part is hot. You may need to remove a few screws to take off the back cover and check inside the fuser.
Posted on Jul 24, 2009
  • 26 Answers
SOURCE: I have infoprint 1125 that shows 202 paper jam, but no jam
Usually it is the white roller that is going bad in the tray. These are easy to replace - but fragile. They have a small clip that may break if you push it to hard. If you dont have a replacement - try cleaning them real well. If that doesnt work - you can take it off and remove the "tire" part and put it back on inside out. It fits funny but works if no parts are available.... All the rollers are the same for almost all printer like this.
Posted on Nov 30, 2009
Why does my copier "rear jam" and wrinkle the paper after the fuser?
replace the fuser and check for a blockage after the fuser
Jul 11, 2014 | Sharp AL 1631 Copier
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Wrinkled Paper
Check paper path,especially near fuser.If all ok fuser is faulty.
Jul 10, 2009 | Samsung SCX 4521F All-In-One Laser Printer
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Wrinkled jammed paper
paper weight to light change it.
Sep 11, 2008 | Brother HL-2040 Laser Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Paper completely wrinkled
NONERIGHTNOW, HP makes great laser printers, the commercial LaserJets typically last 8+ years without much more than an occasional maintenance kit to keep them going. The 1000 series printers are quite another story, they are designed for the low end printer market and just can?t take hard usage over time. The typical culprits with paper wrinkling are heat from the fuser or paper problems. -In the paper tab of the printer driver make sure the correct media is selected. This controls how hot the fuser gets which also causes paper curl/wrinkling. -Buy some fresh HP grade paper, improper humidity, coatings and storage can also cause problems. -Try a new HP cartridge. If you still have no success starts a print job and turn off the printer while the paper is feeding. What you want to do is try to freeze the wrinkling process so we can identify what area is causing it. Post this information. Also open the rear, straight through door; also let us know what happens. Let us know how it goes and please don?t forget to rate this posting.
Jan 19, 2007 | HP LaserJet 1300 Printer
IBM Infoprint 1532 Laser Printer Logo
20 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
