Question about Amana Ovens
WE have a Amanda oven. model# arhg87003 sn 9610231599.When i try to turn on bake to peheat it turns it self off and fo shows on read out.And will not heat up.What is going on?
  • Michael Masters
    Michael Masters May 11, 2010
    Is this a range or a regular single oven?
watugot
  • 290 Answers
SOURCE: OLD GE Wall Oven doesn't heat properly
On these older ovens ther is usually always 120 volts on the elements at all times.
If you check across the element ends with it in bake you should read 240V. If not, there is a problem with the control. With the voltage drop you describe, it sounds like you are losing power on one line of voltage coming to the element.
Post back to let me know what you find out or if you have any questions.
Posted on Nov 24, 2007
  • 33 Answers
SOURCE: Oven does not work after running self cleaning
Dear Dupe,
please rate this solution if it mends up ur needs,else choose fixya,
please do the following checks,
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Check the thermometer bulb
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • please rate this solution if it mends up ur needs,else choose fixya.Thank you
    Posted on Dec 17, 2008
    SOURCE: Kenmore Ultra bake self cleaning oven is showing code E0 - F2
    My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
    Posted on Aug 27, 2009
    • 41 Answers
    SOURCE: We have a whirlpool oven model #RBS305PDB8 last
    There is a design problem with certain model Whirlpool ranges where the thermal fuse blows during self-cleaning (auto-clean). This may be because of inadequate insulation, causing the outer panel to overheat. When the thermal fuse is replaced, the range will work, but it will blow the next time auto-clean is done. To safely work around the problem, the thermal fuse may be replaced with a thermostat, which will reset itself once the oven has partially cooled off. If the part number of the thermal fuse is 9759243, it will blow at 120 deg C (248 deg F). This can be replaced to a Selco Part# SES-L250 thermostat. The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
    Selco part# SES-L250 specs:
    Surface Mount
    3/4 in. disc
    120/240 VAC
    25 A
    SPDT
    open on-rise (normally closed)
    open (cut-out): 250 deg F
    close (cut-in): 220 deg F
    temperature differential: 40 deg F
    Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/surface-mount-automatic-reset-open-on-rise/pn-5113?&seo=110
    Available: Selco distributors: http://www.selcoproducts.com/distributors.php
    and online at
    Allied Electronics http://www.alliedelec.com
    If the Selco SES-L250 'surface mount' thermostat is not available, an 'airstream type' thermostat can be used with a few differences:
    1) I recommend to replace it to a 240 or 230 deg F thermostat. The reason for the lower cut-out temperature is that an 'airstream mount' thermostat will not be flush with the back panel, as is the original 250 deg F 'surface mount' one, so it may cut-out at a higher (unsafe) temperature.
    2) I recommend to add Heat-sink compound between the thermostat and the sheet metal. This is used for computer processors and is available at computer and electronic component stores.
    3) An 'airstream type' thermostat is thicker than the original 'surface mount' one, so longer screws will have to be obtained. The sheet metal tabs on the thermostat will bend slightly when installing.
    4) The terminals are perpendicular (90 degrees), so they have to be bent to 30 degrees for the wires to fit behind the back panel.
    Recommended 'airstream type' thermostats:
    Supco L240
    Info: http://www.supco.com/images/pdfs/2009%20HVAC%20Caralog/2009%20Catalog%20for%20Web2.pdf
    Available: http://www.appliancefactoryparts.com/applianceshvac/supco/crossref/thermostats2.html
    Selco SE-L240
    Info: http://catalog.selcoproducts.com/item/3-4-disc-thermostats/ts-3-4-disc-se-series-airstream-mount-open-on-rise/pn-5096?&seo=110
    White-Rodgers 3L01-230
    Info: http://www.white-rodgers.com/wrdhom/pdfs/06_Cat_pages/Cat_06_pg0092.pdf
    General Electric LS2-240
    Posted on Nov 03, 2009
    SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Posted on Mar 16, 2010
    Oven will not turn on after self cleaning has finished
    If electric turn the oven to bake and look at the bottom element. If if does not turn red hot, it may be defective.
    If gas, turn to bake and watch the igniter to see if it get red hot. If not, it may be defective.
    May 22, 2014 | Ovens
    My oven will not heat up to temperature
    It may be the bake element that has gone out. The self clean usually uses the broil element to heat the oven. And most oven will either put 120 volts to the broil element while baking or pulse the broil element while baking. This will cause the oven to get warm but not hot. Check the oven bake element it cound be bad or a wire may have burned off.
    Feb 14, 2014 | Ovens
    We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
    try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
    Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
    Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean'...
    Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
    Nov 04, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Can not activate the self cleaning cycle
    Before you try to use the self cleaning feature please read this tip....
    http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
    You out to see all of the problems that come here everyday because of the selfcleaning feature on ovens....
    Heatman101
    Mar 08, 2010 | Viking Ovens
    Require Electronic Oven Control Guide for a drop in/slide in electric range model Model CFES365EC Frigidaire range self cleaning free standing
    the problem with the oven is that,when we start it to bake sumthing it turns of automatically after half and hour,and it doesnt bake anything...can you please help us with this problem...
    Sep 16, 2009 | Frigidaire Ovens
    How do i turn on the bake option on the self cleaning oven?
    to just turn on the bake option there should be a bake button to press as well as a self clean option and broil cycle.
    Jun 21, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
    Touch pad does not work and flashed FO
    FO- the touch pad is faulty. replace the eoc(electronic oven control)
    May 17, 2009 | Kenmore Ovens
    Linking F3 when trying to turn on the oven
    While using the self clean feature you burned out the oven temp sensor.
    Replace the oven temp sensor.
    Do not use self clean on any oven unless you want to replace parts,
    Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
    Bake element doesn't turn off
    The relay controlling the element has likely failed and welded it self closed. This parts is normally built into the electronic control board, which costs somewhere around $200 to $300 to replace.
    Try http://www.searspartsdirect.com/ for the part. If are not familiar with repairing appliances, you might want to refer this to a professional.
    Jan 08, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
    Ovens Logo
    209 people viewed this question
    Top Amana Ovens Experts
    Oloyede Monsuru
    Joseph Hoffmann
    john mabry
    Are you an Amana Oven Expert? Answer questions, earn points and help others
