Question about Kyocera Office Equipment & Supplies
Kyocera KM-C2525E touch screen does not work
The screen does not respond to any of the options picked in amy mode.
SOURCE: kyocera km-2050 scanning function
The km 2050 was on network, but moved to home and directly into tower system via usb interface connector. Printer works, but can not get scanner to work? read instructions without a clue. can someone help with correct proceedure?
Posted on Mar 12, 2009
cbtmaya
  • 84 Answers
SOURCE: error code C-6 for kyocera km 1500
c6-400 code error is poor connection (power supply)
press start and clear/stop button
the code is inizialized
Posted on Aug 31, 2009
xptareq2000
  • 1447 Answers
SOURCE: kyocera km C-6
Hi my name is xptareq2000 .My copier error code is 000 C6
How can i reset it please help me any one
Posted on Jan 19, 2010
  • 62 Answers
SOURCE: Printing problems Kyocera KM 2050
when this error comes up..hit the print button on the left hand side..this will than tell you on the screen wha the actual problem is..i.e ( out of paper...lost connection etc
Posted on Feb 01, 2010
  • 165 Answers
SOURCE: How to reset maintance call on kyocera km-1635?
10871087 then 251 then hash key then set it to 0 or cancel to reset the counter
Posted on Apr 05, 2010
When i connect my kyocera km c2525e to the computer its picked as OEM 2JL-25C
Hello, connect your copier in a network and you can use the drivers from this page https://www.kyoceradocumentsolutions.eu/index/service/dlc.false.driver.KMC2525E._.EN.html
Feb 23, 2017 | Kyocera Color Copier, Km-c2525e
Kyocera service codes
It's a firmware mismatch error did you just replace the touch screen or the whole control panel
Aug 25, 2014 | Kyocera Km-4050 With Feed, Finisher, Bank,...
How can fix the error message c7104 in Kyocera c2525e
this code is saying you have a bad yellow dv unit you have to have a new 1
May 06, 2014 | Kyocera Color Copier, Km-c2525e
C2525e touch panel not working
Run a business card between the touch screen and the outside surround. Dirt or dust can make the screen believe that you are constantly touching the screen which will lock up the touchscreen. Try adjusting the screen brightness by adjusting the thumbwheel located at the far top of the display panel.
If this does not rectify the fault then the touchscreen will need to be replaced.
Mar 08, 2014 | Kyocera Color Copier, Km-c2525e
How do I install driver for Kyocera CS 5035 on MAC
Kyocera and Copystar models are the same just replace KM with CS.
The following instructions should help you. TO download the current driver use this link to th emanufacture website; http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?rid=18657.
Kyocera Printer Drivers and Mac OS® X 10.5 Leopard FAQ:
Is the installation for Mac OS X 10.5 the same as for Mac OS X 10.4 and earlier? Mac OS X 10.5 introduced a new printing architecture that requires changes to the installer and installation process. For this reason, Mac OS X 10.5 requires a new printer driver installer.
I cannot see my Kyocera AppleTalk® printer. How can I make it visible to OS X 10.5? AppleTalk is disabled by default in Mac OS X 10.5. Enable AppleTalk to discover your Kyocera printer.If you use the Kyocera installer, a message will appear, asking you to enable AppleTalk. Click Yes to continue the installation.
I cannot find Printer Setup Utility on Mac OS X 10.5. Is it still supported? Apple has removed Printer Setup Utility from Mac OS X 10.5. To install a printer, open System Preferences and click Print & Fax.
When I manually install a printer, multiple PPD files are listed for the same Kyocera model. Which should I choose? When manually installing a printer or changing a PPD for a installed printer, both Linux and Mac OS X PPDs are listed for some older Kyocera models due to a change in PPD handling in Mac OS X 10.5. Linux PPDs can be identified by the word Gutenprint in the PPD filenames.
Supported Multifunction Printers: KM-1650, KM-1815, KM-1820, KM-2050 ,KM-2530 ,KM-2550, KM-3035, KM-3050, KM-3530, KM-4030, KM-4035, KM-4050, KM-4530, KM-5035, KM-5050, KM-5530, KM-6030, KM-6330, KM-7530, KM-8030, KM-C830, KM-C830D, KM-C850, KM-C850D, KM-C2520, KMC2525E, KM-C2630, KM-C3225, KM-C3225E, KM-C3232, KM-C3232E, KM-C4008, KM-C4035E, CS-1650, CS-1815, CS-1820, CS-2050,CS-C2525E, CS-2550, CS-6030, or newer. Supported Printers: FS-820, FS-920, FS-1018MFP, FS-1020D, FS-1030, FS-1100, FS-1118MFP, FS-1300D, FS-1800, FS-1800+, FS-1900, FS-1920, FS-3800, FS-3820N, FS-3830N, FS-6020, FS-6026, FS-9100DN, FS-9120DN, FS-9500DN, FS-9520DN, FS-C5016N, FS-C5020N, FS-C5030N, FS-C8008N, FS-C8026N, FS-C8100DN, or newer.
I hope this is helpful,
Shawn
Mar 08, 2011 | Kyocera Copystar CS-5035 Copier
Kyocera mita 3035 is offline cannt figure out how to get it back online
If you are taking about the printer portion. Just hit the printer button on the left hand side. When the printer options pop up on the touch screen chose the option on the bottom right hand side (the GO key) of the touch screen that should bring it back online.
Hope this helps.
Aug 06, 2010 | Kyocera Mita KM-3035 All-In-One Laser...
Copier km-c2525e will only print 1 page of document
Hi
it might be a long shot but have you got an add toner message on your copier screen.
When toner is required the copier will only print on page at a time.
Alternately you should ensure that you have not selected a partial print  eg
print current view or print current page.
if all this fails, reload the driver and or your Acrobat reader
hope this helps
Aug 14, 2009 | Kyocera Office Equipment & Supplies
We have a Kyocera 5035 Copier and getting a message "Page tray is out of order"?? Any ideas on what to do?
if you go into copy mode punch in 1087 1087
press the green start button
punch in 906
press the green button
select the option on the touch screen
and wait until the machine reboots
this should fix any minor problems
Jan 24, 2009 | Kyocera Mita KM-5035 Printer
44 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
