Question about Danby DTT420 Top Load Washer
It doesn't spin st enough - Danby DTT420 Top Load Washer
Barbie power wheel just spins doesn't move
some people stud the tires with screws, or rubber traction bands can be purchased, or just put rubber bands on the tires for indoor use
May 15, 2017 | Fisher Price Power Wheels Barbie Jeep
Washer doesn't spin and drain
Possible blockage in 1 of the outlet pipes causing it to not drain out fast enough and keeping the clothes wet.
Dec 22, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Turn on cpu and it doesn't boot
open your pc panel, look for the heat-sink fan over your cpu(processor). there is a small fan over it and if it is not spinning your PC will not boot. could be a wiring issue where the wires(white/red usually) are broken or not connecting to motherboard good enough. check those but be careful no to break wires or connections. you may need to replace the heat sink module. if any capacitors on motherboard are swollen(little cylinder looking objects with + mark on top) will indicate overheating and motherboard may have failed. if fans spin on heatsink, then pc boot file may be damaged where then a shop will cost to fix it. fans will be the cheap fix else$$$
May 18, 2012 | Dell Inspiron 537 ST PC Desktop
Maytag MHWE450 spins fine at full speed mid-cycle, for instance between wash and rinse, but will not spin after rinse or on "drain and spin" option. There are no error codes. Seems it might be...
Hello K.W. ,
Sad to sad their is no way to reset the control and yes it sounds as if has diagnosed it spot on ...since it spins on the rinse cycle the motor can be ruled out totally as the problem since its up to the control to tell the motor what to do and when to do it so if it spins sometimes and not others it seems to be the control that's not telling it to spin at the end. One thing to check though is that the filter screen perhaps is clogged since i believe it doesn't spin at high speed until after the water has drained and if the filter on the pump is built up w/debris its not going to drain fast enough so while it may not solve it,it may solve it by checking the drain filter. This tip i wrote will show ya how to check the filter on the pump.http://www1.fixya.com/support/r10121384-check_when_duet_washer_door_locked_after
If the filter is relativity clean and doesn't solve the problem the control baord would need to be replaced.
Sep 27, 2011 | Maytag MHWE450W Washer
Makes clicking noise while spinning. The noise lessens as the spin speeds up, but it doesn't spin enough to get the water out of the clothes.
well by your statement the first thing i would try and do is change the belt,,i believe onthejob5130_0.gifit maybe defective ,,thers a picture of belt and one of how it goes on,,which entails removing the motor good luck...onthejob5130_6.jpg
Sep 11, 2011 | Maytag Admiral AAV7000A
Car runs great for 10 minutes then shuts off and has to set about an hour before restarting and will only spin over yet has spark and fuel pressure
This sounds like a bad control module, run the car until it dies then remove a sparkplug wire from a sparkplug and stick a screwdriver into it and place it near a ground then have someone spin the key as you watch for spark, if theres no spark then i would say its a bad ignition control module. this is common, when it gets hot is dies out, you can even remove it and have it tested at an auto parts store just make sure they test it a few times to get it hot. good day.
Jun 27, 2011 | 1989 Chevrolet Celebrity
I have a L G and it does not spin dry the wash load How can this be fixed
Do you mean it doesn't spin at all...or it doesn't spin fast enough to dry the clothes?
If it will not spin at all you may have a loose belt or broken belt.
If it does not spin fast enough, you may have a loose belt or too latge a load.
Jun 26, 2011 | Washing Machines
I have a kenmore 80 series and its not spinning out the water.
does it drain out the water and spin but the clothes are still wet or is it not draining or spinning?set the timer to spin,open the lid and stick a screw driver into the lid switch hole and see if it spins and drains,also if it doesn't push down and let the switch up,or close the lid down and open it a little do this a few times,you should hear the switch make a clicking sound,if it doesn't click you have a bad lid switch.if the machine is draining and spinning but the clothes are wet,do the same thing with the lid switch and watch it spin with the lid open,is it spinning fast,if not you have a bad transmission and it's not spinning fast enough to remove the water out of the clothes or you could have a kink in the drain hose or something in the pump and it's not draining all the way.let me know what you find and send the model number off of the washer,the number should start with like 110.
Apr 14, 2011 | Kenmore Washing Machines
Whirlpool front load washer won't spin - just sometimes
Most Whirlpool (Hotpoint) machines have "out of balance" sensors that detect very large movements of the drum suspension usually due to a very badly balanced washing load.
This can occur for various reasons but putting large and/or heavy items in can trigger these sensors i,f as the machine starts to spin, the items dont get distributed evenly around the drum. This is more likley with large/heavy items.
The machine will then restrict the spin speed for the remainder of the wash cycle, and once the machine is switched off, the next time the machine is used it returns the spin speed back to normal - but if it detects an out of balance situation, it will again restrict the spin speed.
It sounds to me the machine is acting as designed. You could try positioning the items differently as you load them, and hope they dont end up "all over one side".
Oct 06, 2017 | Whirlpool CAM2752KQ Top Load Washer
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Danby DTT420 Top Load Washer Logo
20 people viewed this question
Top Danby Washing Machines Experts
shaun taylor
Jim Y
Jim Y
Samyfam
Samyfam
Are you a Danby Washing Machine Expert? Answer questions, earn points and help others
