Question about Daewoo DTQ-14U5SC 14" TV
Standby Light Keeps Blinking. Can't get TV to come on.
I plug the TV in and all i get is the blinking of the Standby Light. Manufactured Nov. 2004 Can Someone help to Figure this out. Nice TV if it would work. Thanks
  • Guy Plante Aug 02, 2009
    Thank you so much, I think it's the second. And that's something i can't fix. Thanks again.
  • Daewoo Master
  • 19,396 Answers
The TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expense, just locate any good qualified repairer.
Posted on Jul 03, 2009
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
When you turn it on, the green LAMP light goes on, then it clicks and the STANDBY/TEMP red light goes on, then clicks and back to the green LAMP light. It does this a few times, then The TIMER green light...
Usually if all 3 indicator lights come on this could be the color wheel is not functioning or the DINe chip needs to be re-soldered. Be sure the lamp door is closed all the way, but the color wheel needs to be looked at first.
http://tvtechwork.webs.com/
Nov 17, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Standby lighy blinks tv won't turn on
error code 4 is vertical deflecton failure . replace the vertical deflection ic. and the electrolytic capacitors in the vertical circuit. Or if you are lucky just resolder the vetical IC and resolder th horizontal section too.
Sep 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Light blinks four times, screen doesn't turn on
PER TO WHAT SONY HAS TO SAY IT IS A VERTICAL PROBLEM. SOME TIMES TH EIC JUST NEEDS TO BE SOLDERED. IT IS ON A SMALL HEAT SINK IC545. IF IT IS NOT SOLDERED GOOD THE YOU PROBABLY NEED TO REPLACE IT.
There are three defects can cause the Standby/Timer LED to flash in groups of four:
1) +13V and/or –13V from FBT/pins 9 and 7 respectively are missing on Vertical Drive IC545.
2) Vertical Drive IC545 is defective (no reference pulses output on IC545/pin 3 to IC001/pin 78).DON...
Mar 09, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Screen Doesn't turn on, light blinks four times
Good day.
First, A resistor looks like a little tube with different colors placed in stripe form and has two ends or terminals. The colors represent the value the 1st and 2nd 3rd being the significant digits. The 3rd is the multiplier and the 4th is the tolerance.
Consider the vertical IC of your unit being the cause of this. Also, there are cases wherein the X-ray protector resistor is to be blamed.
chris
Mar 08, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Daewoo DTQ-14U5SC 14" TV Logo
720 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
