Question about HP PSC 2355 All-In-One InkJet Printer
Feds paper half way and jams
WHEN PRINTING THE PAPER GET HALF WAY THROUGH AND JAMS, WHAT CAN THE PROBLEM BE????
Soulvisitor
  • 1113 Answers
SOURCE: Hp laser jet 1020 paper jam and not printing
REmove cartridge, and open rear door, might be all scrunched in very back fuser unit, if you can't remove it without damaging the rollers then it will need to be pulled to bits
Posted on Dec 27, 2007
SOURCE: HP 1020 Issue
Maybe if you hold down the cycle button and let it run through a "test cycle" to receive a printer data sheet it might clear the internal buffer or whatever you call that short term memory these printers have. Let us know. JP
Posted on Mar 17, 2009
SOURCE: paper jammed
found the paper stuck inside and pulled it out with a pair of pointy nose pliers, very carfully so as not to rip the paper. I finally pulled straight out.
Posted on Mar 24, 2009
manojro
  • 495 Answers
SOURCE: the printer says Paper Jam even there is no paper in it
Please try to clean paper jam area with referring to instruction manual. You printer needs cleaning...
Posted on May 04, 2009
SOURCE: HP PSC 1510 ALL IN ONE
salut ROSENEDKER !
demonte entierement ton hp psc 1510 entierement et regarde du cote droit a la station de nettoyage;il ya une petite target qui doit etre cassee du cote haut ou bas . je dis bien cette target se trouve au bout du bloc des rouleau avance papier avec un ressort de rapel accrocher dessus . Merci et bonne chance
Posted on May 26, 2009
When printing documents no matter how few or how many pages, paper gets stuck in the middle of printing.
Try using regular paper on unit as specified by Samsung. If that does not resolve the issue then the hassle lies with the paper feed mechanism. Often a good cleaning of all the rollers in the path can take care of the issue.
Aug 24, 2015 | Samsung ML 2525 BW laser Printer
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Canon ir2016 jams papers under registration clutch. the clutch runs on power up but does not run when copig or printing help
This seems to be a common problem for the Canon ir 20 xx series machines. The problem is having machine indicating paper jams on the left hand side of the machine. When you open the left cover you do sometimes find paper stuck on entering the fuser unit. The main problem, and loads of these machines with these problems have been fixed, are the half moon pickup rollers! Clean the pickup rollers or even better, replace them and you will get the machine working 100%!! To confirm this try copying from the machine using the manual feed tray. You will never get a paper jam. This fault is due to incorrect pickup resulting in timing problem and thus getting paper jams! Good luck!
Mar 10, 2014 | Office Equipment & Supplies
Papr Jam, Samsung CLP310 - paper jams half way through the job
If it jams every page, it is the infamous Samsung design flaw. There are dozens of reports of this problem all over the internet. The best solution: sell it or otherwise get rid of it ASAP and buy another type or model of printer. The 2nd best solution: call trained technician and ask to replace the broken part. It could be thermistor near fuser, some people say it is a photo-interrupter.
May 02, 2010 | Samsung CLP 315 Laser Printer
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
ADF paper jam
Are you printing at the same time your printer could be running out of memory
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Paper feed problem
The fault is the paper stop sensor is broken. Have the same problem myself. I don't think there is an easy solution to this as the sensor arm will have to be replaced and I think the m/c would have to be stripped down to do it. Nice to know if anybody has any ideas though.
Nov 09, 2007 | HP PSC 2355 All-In-One InkJet Printer
Paper jams/ printing blank
Thoroughly check for very small foreign objects in your printer, and check both behind in paper feeder area and inside the unit. Jams can be tiny pieces of paper than have gotten in or torn off paper fed in at slight angle but you may not have noticed. Service you printheads and rollers both manually with solution and cotton buds (q tips) and then see if your ink may be low or out, blocked printheads will obstruct ink from flowing at all. So will damaged printhead points on cartridge, signalling replacement time.
Aug 14, 2007 | HP PSC 1215 All-In-One InkJet Printer
HP PSC 2355 All-In-One InkJet Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
