Question about Nikon COOLPIX S7 Digital Camera
I need discharge the pictures from my camera nikon, how can i do
    New Friend:
  • 70 Answers
You can tranfer the pictures using a data cable which u get with the camera connect it to usb prt in you pc or laptop and start transferring.
Posted on Jun 18, 2009
Nikon coolpix 59500
The most likely cause is a bad battery. But before you throw it out, try discharging it and then recharging it.
Probably the fastest way to discharge the battery is to turn on the flash and start taking pictures. It doesn't matter what you take pictures of, you're going to throw them away afterward. Just point the camera away from you and start clicking. Take a hundred pictures or so, or until the battery level drops below 25%, or the flash recharge time gets very long. Note the battery level, then recharge it overnight again and see what the level goes to.
Jan 17, 2014 | Nikon COOLPIX Cameras
Nikon L110 battery getting discharge in few clicks
It could be a bad battery charger circuit in your camera. Try charging your batteries in an external charger. Adorama.com sells an Delcon Devices external battery charger for $9.95. If that works, your problem is solved. If not, you will need to send the camera to Nikon USA for repair.
Jul 11, 2013 | Nikon Coolpix L110 Digital Camera
D1oo Nikon enel3 lithium Battery packs stopped working
Batteries don't live forever. When handling them correct they can survive 1000 charge and discharge cycles. When taking an average of 200 pictures per charge, the battery could survive the camera shutter.
Try to use a battery till it is almost empty. The camera will give a warning when you need to replace (or charge) the battery. When you want to go on a trip or need to make a series of foot's you should take only charged batteries. When you don't use a camera, for a longer period, don't leave the battery in the camera. It could start leaking and damage the camera. But when the battery was not used for a longer period, please charge it before using it again.
This could help you to keep your batteries in better condition and let them live longer.
Dec 06, 2012 | Nikon ENEL3 Lithium Ion Battery Pack
Battery life nikon coolpix s3000
If the rechargeable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Oct 06, 2012 | Nikon COOLPIX L18 Digital Camera
Hello. The batteries on my speedlight discharge
if you are using regular batteries I can't help you, but if your using rechargeable batteries then the cause is old batteries, after many charges they don't charge well anymore. and you need to replace them
Mar 19, 2011 | Nikon Speedlight SB-800 TTL Flash
I have a Nikon D80. The flash is not working.
if u r getting green signal of flash charging,then discharging section is defective,sochaque the section replace the parts xenon tube etc or take it to a tech.
Apr 02, 2010 | Nikon D80 Digital Camera with 18-135mm...
NIMH Battery goes off after 20 shots for Nikon Coolpix L01
the camera takes just about any AA pair of batteries ... lithium will give you the most pictures .. your NiMH batteries should last longer unless they are old .. you may have one weak battery ... you can try a pair of standard alkalines to see if there is something wrong with the camera .. if those work ok then you need a new set of NiMH ... there is a new type out called "eneloop" .. they are just like normal NiMH except they dont go dead when you store them .. even after a year they are still charged .. with normal NiMH batteries as they age they will self discharge in 2 weeks or so .. so you have to charge them just before you use them ..otherwise they go dead on their own .. if you charge them then not use them for a week then you will not get nearly as many pictures ... the eneloop batteries fix that .. you can also recharge them many more times than standard NiMH batteries .. they cost about the same ..
Oct 06, 2009 | Nikon Coolpix L1 Digital Camera
Nikon D90 problem!
contact to nikon you have the warranty.
Apr 10, 2009 | Nikon D90 Digital Camera with 18-200mm...
Nikon D80 with 400 IS lens
I think you should replace your camera battary with suaitable one.
Mar 03, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon COOLPIX S7 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
