Question about Acer H233H bmid Monitor
On/off button not working Acer LCD Monitor H233H
The on/off button on my monitor Acer LCD Monitor not working, looks like it's broken. Doesn't want to spring in or out. How can I fix this myself, cant afford to pay someone else, nor buy a new monitor
Benimur
  • 6966 Answers
SOURCE: Windows XP Pro. driver for the acer LCD Monitor X193W
To my knowledge, it is compatible and certainly would work with XP. Since this monitor has both DVI and VGA inputs make is compatible for most video cards or even a built-in video of the PC. If for some reason the Acer X193W would not work with your Windows XP PC, possible reasons are:
  • Screen Resolution and/or Screen refresh Rate of the PC's Display Properties too high, try lowering them down;
  • hardware fault either on the monitor or video card;
  • incorrect/missing drivers of the video card;
  • it is being hooked as a secondary monitor and the dual/twin view is not activated.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 08, 2008
SOURCE: Drivers for the Acer LCD monitor X193W under Windows XP Pro.
The acer LCD monitor is plug and play.You don't need a driver.But unless you have a graphics card that supports at least 1440x900 you have problems. Also if your card has a div connection, use that instead of the analog connector, The monitor comes with that connector. Use the old one to connect a second CRT monitor if you want. Don't connect both to the lcd monitor and to the computer unless you are using a second monitor. Like everything these days, every purchase seems to need an upgrade of sorts, On board graphics **** anyway. Buy at least a 128 MB graphic card with a digital connector and more RAM never goes astray.....
Ron
Posted on Dec 30, 2008
smwsolutions
  • 73 Answers
SOURCE: Recently, I purchased an Acer H233H LCD Monitor
Try installing the Acer Monitor software and disabling the the desktop sound card under 'My Computer'. 'Properties','Hardware Devices'.
Let me know if you need help doing this, or need more help.
Posted on Jul 25, 2009
SOURCE: I have no sound on my Acer monitor
ACER X223W have no speakers build in. You must use exstra speakers or a headset.
Posted on Jul 26, 2009
antiochpc
  • 1314 Answers
SOURCE: My monitor has a yellow line running down the middle
This is a bad LCD panel. If it is still under warranty, your best bet is to have it replaced again. The only fix is to replace the actual panel and that would cost more than a new monitor.
Posted on Sep 28, 2009
Acer LCD monitor AL2016W- colors are fuzzy and jumpy and I don't know how to fix it!y
LCG monitors are cheap these days. You can get a decent one for right around 125.00
Terry
Aug 31, 2014 | Acer AL2016W 20" LCD Monitor
H233H monitor bad video
maybe some component in monitor is broken
go to service monitor station to chek it out
Dec 21, 2013 | Acer H233H 23 inch LCD Monitor
Acer h233h monitor has blue tint all over screen
It's any one of these issues in decreasing importance video cable, video card, monitor. Make sure the video cable is plugged into the monitor and computer firmly first. After that, start replacing until you hit the culprit. You should be able to take any one of these items back to the store if it doesn't fix it.
Oct 22, 2012 | Acer H233H BMID 23 Widescreen HD Flat...
Sir/Madam im shiva from chennai , i have acer AL1713B lcd monitor , but my prob is when i connect the power cable the led light is working , but display is not working. how can my solve this prob?
Dear Sivakumar,
please try to remove and plug VGA cable back again to the monitor. and press the menu button in front of monitor if it doesn't giving any message in monitor it means that the control card inside the monitor is faulty.for fixing that you have to contact your local service center.
Thanks
Jun 18, 2011 | Acer AL1713 17" LCD Monitor
Why is my acer lcd monitor model H233H continuing to blink on the on off button and the screen is black?
Look for bad caps with domed top in the power supply/inverter board, very common on ACER and all other brands as shown in my albums.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 04, 2011 | Acer H233H bmid Monitor
My Acer monitor won't turn off It stays on even when the computer is shut down.
There are some monitors which do not urn off when you shut down the computer,you should switch them off by their buttons.i myself has that LCD
Jul 20, 2010 | Acer AL1706AB LCD Monitor
I cannot adjust the color on the screen. Too Blue
mcdevito75 here, On the monitor itself press the auto button for factory settings, if this doesn"t work, press the menu button for adjusting contrast, color etc. if this doesn"t work your monitor may be going bad.
Jul 17, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Acer H233H bmid Monitor Logo
89 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
