Question about Golds Gym Exercise & Fitness
My treadmill turns on but wont go
My treadmill is plugged in and power comes on but the the belt won't move . I press the speed button and nothing happens can you help me We have unplugged the treadmill and plugged it in again could there be a fuse of some sort Golds Gym
SOURCE: bodyguard t300 treadmill. belt will not turn
Smashed harness created short.
Posted on Jan 27, 2009
2manyhobbies
  • 129 Answers
SOURCE: Is there an online repair manual for the Golds Gym
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Posted on Mar 01, 2011
ercupa190
  • 12223 Answers
SOURCE: Treadmill won't start. Console works but when
If the console takes batteries, replace them. If this does not work or your console does not require batteries, check the reed switch or optic sensor. Reed Switch: Unplug the treadmill and remove the motor hood cover. The reed switch is mounted on the frame next to the front roller pulley. There is a magnet glued into the front roller pulley. When adjusting the reed switch, make sure it is pointing directly at the magnet. Move the tip of the reed switch within 1/8" of the magnet. Also, check to see that the wire is not damaged, and is connected to the console
Optic Sensor: Unplug the treadmill and remove the motor hood cover. The optic disk and sensor are located either at the end of the motor or the right hand side of the front roller. The optic disk spins between two sensors on the optic switch. The disk must spin freely without touching either sensor. The sensors can be moved by loosening the adjustment bolt holding the switch to its bracket. The switch can then be slid. Center the disk.
11_21_2011_11_34_59_pm.gif11_21_2011_11_35_24_pm.gifRemember the Display Console Board has circuit that send to PController Motor, and after you did the adjustment you can conclude if the Sensor Reeed is faulty, 2) The Display of 3) The main Controller Motor.
Posted on Nov 21, 2011
ercupa190
  • 12223 Answers
SOURCE: i need the manual from golds gym crosswalk 570
go to www.iconservice.com give you model, etc and download for free.
sincerely. Happey new Year.
ernesto cuadra
managua, nicaragua
Posted on Dec 26, 2011
jerry_kramer
  • 3904 Answers
SOURCE: My treadmill won't run, but turns on
It sounds to me like during its move the drive belt came off off the motor that connects the motor to the walking surface. If the motor is not running at all after checking that I would look for a reset on the motor itself and check all connections. Not likely that the motor is fried but that would be the last in line for checking.
Posted on Aug 31, 2012
I have a Proform 1026 EXP treadmill that began running at full speed whenever it is turned on. The incline controls function normally but the belt speed is incredibly high. When set to 1.5 MPH (the slowest...
please run the Software calibration see the instruction.
GOD BLESS you
The Steps for Newer Style Console Calibration
1. Locate the calibration area on the rear or underside of the console (a hole, near the console's center, that goes through to the electronics board. (This hole should not have a screw in it.)
2. Insert a pencil (eraser end), into the hole and feel around for the cal button (will click when pressed).
3. Press the button 2 times (with the pencil eraser). The first click should show CL11 in the console, the second click should show CL21.
4. If the process was done correctly, and CL21 appears in the console, you are in "calibration mode." The next few steps consists of pressing buttons on the console and observing settings. This will not require any other tools.
5. Press ENTER. CL22 should display in the TIME window and (??) in the SPEED window.
6. Press ENTER. CL23 should display in the TIME window and (??) in the SPEED window.
7. Press ENTER. CL24 should display in the TIME window and (??) in the SPEED window.
8. Press ENTER. CL25 should display in the TIME window and (??) in the SPEED window.
9. Press ENTER. CL26 should display in the TIME window. You should then see the letter "E."
10. Press ENTER. You should see "SS" or "55" in the console.
11.Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
12. Push the ENTER button. The walking belt should start to move, accelerate to maximum speed, then stop on its own.
13. When the belt stops, the incline should self test by raising to its highest incline position, then lowering back down to its lowest position.
14. Once the incline test is complete, push the POWER button 2 times. The unit should shut off and the console should go completely blank. If this happens, the treadmill is done calibrating and is ready for use.
If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Sep 18, 2013 | Proform 1026 Exp Treadmill Motor Control...
Treadmill powers on but belt won't move - Landice Sprint 8700
see the video and procedd according. However you must LUBE the deck belt very well+rollers bearing front and back+test the drive belt motor, and replace if necessary. God bless you
Jun 18, 2013 | Exercise & Fitness
I believe that my Reebok 8700es was plugged in during a power surge. I bought a dedicated extension cord and plugged it back into the wall and turned it on. Nothing happened. There were no sounds a
Step 1:
1) Please NEVER use extension cord, this will bring dangerous spikes, glitches, that will affect to your treadmills.
Disconnect it and use the specific outlet wall, for your machine
2) I recommend that you use the Software calibration for easy diagnose, troubleshooting and fix it. This will be clear the information code appearing the display.
Go ahead
Step 2:
The Steps for Newer Style Console Calibration:
  11. Push the STOP/START button. For safety, at this point, you should step off, or be off, the treadmill.
  15. If the letter "F" appears in the SPEED or INCLINE window when the power button is pressed 2 times, the treadmill is indicating a failure somewhere either in the SPEED or INCLINE (depending on the window the "F" appeared in). Troubleshooting the failure would be the next step.
Step 3:
Jan 07, 2013 | Reebok 8700 ES Treadmill - Silver Service...
I have an E-4 sign coming up on the treadmill. I still dont have a clue how to calibrate it or anything. i bought it over the internet and there was no instruction manual that came with it. i really need...
Dear Sir:
This is guide for software calibration in Horizon. Please see under your Hood for motor the instruction for step in calibration.
Turn the treadmill power to "On." Place the safety key in its place on the treadmill console.
  • 2 Simultaneously press and hold the incline "+" and speed "-" buttons for approximately five seconds: The console will beep and display the software version in either the "Time" window or the "Calories/Elevation" window.
  • 3 Press "Start" and allow the running belt to begin moving. The belt should start at 0.5 mph. If this speed is not the speed your treadmill starts at, adjust the speed cube screw located under the control board. Turn the screw to slowly to the right to increase the speed or slowly to the left to decrease the speed.
  • 4 Verify this speed is correct by counting the running belt revolutions per minute. At 0.5 mph, the running belt should make four revolutions in a minute for the Alpine and Advance 500 models and four-and-a-half revolutions for all other models.
  • 5 Press and hold the "Stop" button for three seconds to exit the engineering menu.
  • sincerely. God bless you.
    ernesto cuadra
    managua, nicaragua. c.a
    Feb 11, 2012 | Exercise & Fitness
    Treadclimber tc5000 will switch on but start button won't work
    Make sure the power cable is connected to a known good outlet (test outlet with a lamp or some other electronic device) and connected securely to the machine. Make sure the safety key is securely seated or belts will not move.
    Jan 16, 2012 | Bowflex TC1000 Treadclimber
    My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
    How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
    Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
    By Jolie Johnson, eHow Contributor
    updated April 15, 2011
    Related Searches:
    The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
    Instructions
    1. Power Turns Off When You're Using the Treadmill
      • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
      • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
      • 3 Remove the magnetic key from the console then reinsert it.
      The Console Won't Turn Off
      • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
      • 2 Hold the "Stop" button down for a few seconds.
      • 3 Press the "Speed" down (-) button. Remove the magnetic key.
      The Incline Does Not Change Correctly
      • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
      • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
      • 3 Remove the key from the console.
      Walking Belt Slows
      • 1 Unplug your C2500 and remove the key from the console.
      • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
      • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
      • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
    Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
    I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
    Dear Sir:
    I can read you trouble, and follow the next steps:
    ALIGNING AND ADJUSTING THE RUNNING BELT
    The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
    Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
    Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
    E. CUADRA Managua, Nicaragua. C.A.
    Sep 26, 2011 | Precor C954i Commercial Treadmill
    The treadmill will sometimes start and most times will not, even though there is still power. Then I will be on and the belt will stop turning. I can move the incline level but that is all.
    With the motor cover off and the power on, make sure there is a red light/led lit on the controler, if yes then press the start button then press #3 on the speed side. If not lit, you dont have power to the controller. If you had a red light, and pressed the speed button, the light should start flashing just before the walk belt starts to move. If the speed button is pushed and the light on the controller does not flash, you have a problem in the console. This is only fixed by replaceing the controler.
    Sorry.
    Hope this was at least helpfull, Matt
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
    Dec 30, 2010 | Reebok Acd1 Treadmill Motor Control Board ...
    Horizon treadmill won't start running
    The manual said that after lubricating the deck, press Stop and Speed buttons together for 5 minutes and this will reset the lubrication message and the treadmill should work.
    Jan 25, 2010 | Horizon Exercise & Fitness
    Exercise & Fitness Logo
    178 people viewed this question
    Top Golds Gym Exercise & Fitness Experts
     Atlanta Fitness
    Atlanta Fitness
    Level 1 Expert
    Propulsive
    Level 1 Expert
    Are you a Golds Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
