Question about Golden Technologies Scooter-Buzz Lite 3 Wheel
Which way to turn nut to replace wheel? Lefty looseee or righty tighty
  • 1 more comment
  • Terry
    Terry Apr 17, 2014
    Does it also have a cap over the nut or is it all one piece?
  • Terry
    Terry May 02, 2014
    It's lefty loosee... had the car dealership take it off with impact wrench.
  • Terry
    Terry May 02, 2014
    it also was a 19 mm wrench and we were told it was a 17mm... at least the direction was right.
Broken toilet handle
Easy fix go to your nearest hardware store they should have a replacement part on hand. It just unscrews from the back... Good luck and have a great day!
Feb 03, 2015 | Toto Trip Lever For St774S Toilet Handles
Have an older Big Bear and cannot shift the front axle wheel nuts to get at the brake drums. Are they left and right hand threads respectively?
THEY ARE THE SAME ON BOTH SIDES RIGHT HAND THREADS,,,,,,LEFTY LOOSY RIGHTY TIGHTY,,,,HOPE THIS HELPS,,,,
Jul 19, 2011 | 1995 Yamaha YZF 750 R
I'm trying to change the blade on my Plasplugs tile wet saw, after not having used it for over three years. No matter what I do, I can't get the nut off! I've tried WD-40, graphite, hammering...
Try rotating the nut COUNTER-CLOCKWISE.
Usually, nuts and bolts are Righty-Tighty, Lefty-Loosy, but frequently saw blad nuts use a Lefty-Tighty, Righty-Loosy.
They are built so that when the blade starts to turn, it puts a momentum on the nut that tightens it, so that a loose nut won't come flying off, and get someone injured.
Jun 26, 2011 | RTO Plasplugs DWW406US Power Master Wet...
To remove the engine fan on a 1997 tahoe ,do i turn the big nut counter clockwise or do i turn it clockwise ?
lefty loosey, righty tighty, counter clockwise is loosing the fan nut, they are very difficult to remove without the special holding tool.
Feb 26, 2011 | 1997 Chevrolet Tahoe
Which way do i turn the oil drain plug?
Righty Tighty. Lefty Loosey.
Please Vote!!! Thanks!!!
Aug 31, 2010 | 1998 Toyota RAV4
How do I remove the wire brush form a model 9410 grinder?
An ajustable wrench for the 'wire brush end' nut,and a visegrip type plier for the opposing wheel end. Wrap the jaws of the visegrip pliers with tape to protect the spindle opposite the wir wheel. Loosen the nut on the wire wheel end,counterclockwise.REMEMBER: lefty loosey-righty tighty.
Jul 22, 2010 | Craftsman 6" Bench Grinder with Lamp
Witch way does the nut turn on the harmonic ballancer nut
when it come to honda all nuts and bolts are lefty loosy righty tighty
Oct 24, 2009 | 1996 Honda Accord
1991 Honda Accord - Cannot get the axel nut on the wheel to loosen. Is it reverse thread or do I just need more man power?
Did you remove the cotter pin? If so, you will need more manpower. Should not be reverse thread..........lefty loosey, righty tighty!
Jul 16, 2009 | 1991 Honda Accord
Golden Technologies Scooter-Buzz Lite 3 Wheel Logo
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
