Question about Zenith P42W46X 42 in. Plasma EDTV
White lines in picture - Zenith P42W46X 42 in. Plasma EDTV
White vertical lines after changing dlp chip and lamp on Mitsubishi WD-65833. good picture in background.
had white dots on mine as well i changed the dlp chip and put it back together and got the white vertical lines i decided to check all connections and make sure the chip was locked in correctly
it was not locked in securely i reassembled and now problem solved picture looks brand new so always check connections before assuming its the dmd board
Aug 25, 2012 | Mitsubishi WD-65833 65" HDTV
Hen I scan a picture on my brookstone iconvert scanner there are white lines through the middle of the picture. Already tried recalibrating and cleaning.
Jun 12, 2010 | Office Equipment & Supplies
Horizontal line pictures
am getting experience the same problem - horizontal white lines on blurry still pictures - after 2 years. But the video is working properly.
Aug 03, 2009 | Canon PowerShot A430 Digital Camera
CRT TV with a white line half way up the screen
The white line is result of a Vertical failure. Believe it or not, the whole picture is contained in that one white line, but it is not spread out from top to bottom on the screen.
Usually, a vertical failure is IC or capacitor related. Should be an easy, fairly inexpensive fix for a competent repair shop.
Hope this helps you...
Jan 05, 2009 | Televison & Video
RCA F32650 32" White lines with hazy white flickering
Absolutely right about the transistor and also check any adjacent resistors to the transformer and to the line output transistor. Good luck.
Sep 19, 2008 | RCA F32650 32" TV
Casio exilim ex-z700
If the photo shoot out show white , the obscure (quality variation), and even horizontal line ( white lines), and so on over-exposure cases, even if the use of anti-tremor, set to default values are invalid, because the camera shutter fault.
Can't repair by yourself.
It's need repair camera machine shutter.
more detail CASIO Exilim EX-Z700 overexposure
Aug 06, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
P5100 Nikon
I have the same problem as you... Nikon acknowledges that they have this problem on other Coolpix models, see: http://home.nikon-asia.com/pagearticle.php?pageid=43-7cc915b40d
Now, how do we get Nikon to acknowledge that this is a problem on the 5100 as well?
Jul 10, 2008 | Nikon COOLPIX 5100 Digital Camera
White Lines and blurry Pictures
Mar 23, 2008 | Casio Exilim Zoom EX-Z700 Digital Camera
White lines, all white pictures
I have the same problem have you been able to fix it ?
Sep 23, 2007 | Pentax Optio M20 Digital Camera
Zenith P42W46X 42 in. Plasma EDTV Logo
14 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
