Question about Dometic Refrigerators
Dometic refrigerator stops cooling
It runs for awhile, then stops. also stoped working when I turned on the propane tank.
    Top Expert:
  • Dometic Master
  • 7,915 Answers
Possible bad temp sensor
Posted on Oct 03, 2017
SOURCE: Our Danby propane refrigerator has
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Posted on Aug 03, 2008
  • 531 Answers
SOURCE: Dometic refig ndr 1292 not cooling all the time
you may have a defrost problem
Posted on Apr 02, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Refrigerator not working on gas
There is some reason maybe not explained here. But I will help you if you want. Below is a simple test. The manual I need you to make sure if you have the RM2652 or another model to get the correct manual. That model has digital controls and that is controlled by a control board for switching from AC to DC to Propane. If the board will not switch then we need to look for that problem. Dometic, good refrigerate and great support group. Now here is a link to that model number problem solving PDF. With the manual we can work together to solve this. Thanks, Sea Breeze http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Refrigerators%20-%20Caravan%20-%20Motohomes-%20RV/English%20and%20Multilingual/RM2652-RM2852.pdf
Posted on Jun 16, 2009
  • 9 Answers
SOURCE: Dometic refridgerator won't stay lit on Propane
A bit more info is needed. What model #, and how old is it? In back, does it have a computer board (underneath a green or black plastic cover, appros 4" x 6")? Im guessing that it does, ('cause you get an error message,) Make sure that you have a good 12 volts going to the board at all times, and make sure that the glass fuses on the board are not blown. If that checks out, than its a real good bet the you have a defective board. For Americana models, you're going to need a Dometic board, and for other models, an aftermarket board will usually do. Althoiugh the OEM ones have a better chance of fixing your problem.
Posted on Jul 26, 2009
  • 332 Answers
SOURCE: Dometic RM2652 will not cool on A/C or Propane
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Posted on Mar 10, 2010
Why won't my dometic four door fridge work on propane?
make sure batteries ok needs 12 volt to run control board
Aug 02, 2017 | Dometic Refrigerators
My dometic rv refridgerator is not cooling at all on propane or electric?
disconnect thermistor let run if ok replace if not replace board
Dec 23, 2012 | Dometic Refrigerators
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Dometic Fridge Intermittent on 120V
the dometic fridge you mentioned was outsourced by Dometic and they are having problems. (unit 2652) call dometic at 18888674188 and give them your mod and serial number.
May 26, 2012 | Dometic RM2652 Refrigerator
I am new to the RV world. I have Dometic DM2652.
Yes, you can operate the fridge on propane while driving, instead of running the generator for electric operation. However, you should have a dual tank setup to prevent running out of propane.
Propane tanks with OPD valves aren't holding a true 20 lbs of LP, but rather only hold 17-18 lbs of LP. However, if you're swapping/exchanging your tanks instead of having them refilled, you're only getting 15 lbs of LP in the tanks these days, (check the label at the bottom of the tank to confirm). Hence the reason to have a dual tank setup on your RV to get longer run times.
I thought you might want to have a tech manual for your fridge, so here's a link to the Dometic site, you just need to select yours based on the manufacture date, etc.
http://www.dometicmanuals.com/UM/Dometic/MASTERDometic.nsf?Opendatabase
Hope you find this Very Helpful and best regards!
Aug 28, 2009 | Refrigerators
Dometic fridge 'check' light keeps coming on...won't cool
Yes , the check light is there to tell you that your out of gas yes this is true but the device which switches to power is not changing over which will not let the heaters work and will not start the process of cooling, I suggest to inspect the switch and ensure that this is the case first before consulting a mechanic.
May 11, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 will not run on electricity only Propane
sorry but have absolutley no experience with propane run refrigeration, in America never seen such a thing, please repost with another expert,
Dec 18, 2008 | Dometic NDR 1292 Refrigerator
Refrigerators Logo
23 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
