Question about Pioneer PDP-5060HD 50 in. Plasma Television
PDP5060 red light blinks 3 times
Plasma tv shut down and the power light blinks red 3 times then repeats. Is my pioneer dead?
  • 3 Answers
SOURCE: Pioneer PDP 5030 power supply problem
Ok here's how I manage solve the problem... Having the back removed opens the contacts on the interlock switch so I guess if it powers up in this state it senses the high voltages are exposed and for safety shuts down... After this the unit will not power up and the power led flashes red continuously as described before…
After some thought it occurred to me that there may not be a problem at all, just be a simple reset function for this condition… I managed to find an easy solution to this… Just call up the hidden engineer’s service menu – On 3rd generation Pioneer Plasmas it’s as follows > Power down the screen > Hold down the “Input” and “Vol +” buttons on the front > Power the screen up and the Service menu comes up on the screen > You don't need to change anything just simply power off and from then the screen should operate as normal…It did for me so I’m well happy now!!
I hope this information will help someone else one day – Good Luck!!…Rob UK…
Posted on Jan 04, 2008
SOURCE: pioneer plasma no picture with blinking red light
this requires a replacement of the power supply board. This is per Pioneer tech support whom resolved my issue when I called. Hope this helps!
Posted on Jul 10, 2008
  • 84 Answers
SOURCE: Pioneer Elite Plasma TV
This a factory issue and usually requires service. Most cases it is a bad power supply caused by a surge or powering off and on too fast ... sorry I wish I had better news
Posted on Sep 20, 2008
  • 2336 Answers
SOURCE: TV keeps shutting off automatically
Since your plasma is less then a year old, I would suggest to contact the manufacturers to get it fix under warranty. If the plasma keeps shutting off by itself, that is not normal and should be repair.
Posted on Jan 28, 2009
electronick
  • 505 Answers
SOURCE: my 60''pioneer plasma blinks 12 times after i turn it on
looks like 12 blue blinks is a communication with the Digital tuner error. pioneer had a software upgrade/fix for this in some cases, others might need a new digital tuner pcb. I would unplug all power, wait 5 min, plug in (wait1 min) and try it again. If it is software, it should hopefully work. Make sure you pull your cable card if you have one. If it still won't turn on, you probably need the digital tuner board = $200-500 repair. Pioneer is usually very helpful, I'm really surprised they didn't help at all.. They'll want model #, serial # and date of purchase.
Posted on Feb 03, 2009
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Pioneer plasma pro 930hd tv no power
if the power board looks good my guess it is the main ic that is broken
Nov 22, 2017 | Pioneer PRO-930HD 43 in. Plasma Television
Picture went out and no audio, red light on power blinks seven times and repeats.
Physically disconnect the SU board and the SD board. (See precaution # 5)
Plug in the TV and turn it on.
Does the TV shut down and the power LED
blink 7 times?
Yes
No
Replace the Panel and the SU board.
(See precaution #3)
Reconnect the SD board only.
Yes
No
With the SU board and the SD board still disconnected, remove connectors SC2 and SC20 from the SC board (See precaution # 6)
Disconnect the SD board and reconnect the SU board. (See precaution # 5)
Yes
No
Replace the Panel, SD, and SU board.
(See precaution #3)
Replace the Panel and the SD board.
(See precaution #3)
Replace the SC board.
(See precaution #3)
No
Replace the D board.
(See precaution #3)
blink 7 times?
blink 7 times?
Feb 15, 2011 | Panasonic TH-42PZ700U 42 in. Plasma...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Panasonic viera hd tv th 50pz80u
I have the same model and have the same problem. I have an Onkyo receiver that connections to the TV via HDMI cables. If I turn the TV power on first and then the receiver I don't get the blinks.
Dec 14, 2008 | Panasonic Viera TH-50PZ80U Plasma TV
Monitor on switch goes onto green for 3 seconds and then turns to a flashing red, which flashes 5 times quickly,and repeats every few seconds. model is pioneer plasma display system noPDP503HDE
Thats a Factory shut down .... caused by a fault usually the power supply
Sorry it's a factory repair issue
make sure all the connections are tight
and try one more time .... sorry
LB
Sep 19, 2008 | Pioneer PureVision PDP-503HDE 50 in....
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
Pioneer Plamsa CMX 43"
pioneer customer service: 800-228-7221
C-Dog
Feb 10, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP506-HDG plasma tv
The 3 blinks ( i assume they're blinking in red) means a scan assy problem. Check the scan A & B boards and the Y drive board. Something is shorted and loading down the Vscan voltage of the power supply.
C-Dog
Dec 19, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Pioneer PDP-5060HD 50 in. Plasma Television Logo
44 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
