Question about Sony Playstation 3 (PS3) Console
No menu when turned on
When i turn on my PS3 i don't get a memu i only get the back ground and i can't play games from here, when i press the button for the ps3 to go n standby it just beeps and nothing happens. when you press and hold the PS button in it sumtime allows me on this menu i have tryed turning off the system but nothing happens then
is there a way i could solve this???
    President:
  • 2,653 Answers
I can fix this for you.
google: rescuetechla
I'll have a tutorial up in the next two days.
There's one now, but it's a bit complicated.
I'm working on a super simple one.
Posted on Jun 19, 2009
How to you connect PS3 to to model 37PD5000
Good day!!!
Please try this procedure to connect the PS3 to TV..
The PS3 has a Blu-ray drive that can be used not only for playing games but also for watching high-definition movies. The best way to connect a PS3 to a high-definition viewing device such as a video projector is through the PS3's high-definition multimedia interface (HDMI) output. The HDMI connection can transmit up to 1080p high-definition from the PS3 to the video projector using a single cable. Attaching and setting up the HDMI cable will only take a few minutes and will let you watch high-definition video from the PS3 on the video projector.
  1. Connecting HDMI
    • Attach one end of the HDMI cable to the HDMI output connector of the PS3. Turn the HDMI cable around if it does not slip right into the HDMI output, because the HDMI cable can only fit into an HDMI connector one way.
      Attach the other end of the HDMI cable to the HDMI input connector that is on the video projector. Make sure both sides of the HDMI cable is securely pushed into the connectors of the PS3 and of the video projector. Turn on the video projector. Press the "Menu" button on the video projector's remote. Navigate to the "Sources" setting on the video projector's Menu. Select "HDMI" from the "Sources" setting. Press the "Menu" button on the remote control again to exit the Menu.
    Adjusting the PS3
    • Turn on the PS3. Wait for the "Home" menu to appear on the video projector, although the quality of the video seen from the video projector will be muddied and dark. Navigate from the "Home" menu to the "Systems" icon using the game controller and select the "Display Settings" tab. Choose "Video Output Settings" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen.
      Choose "HDMI" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the next screen. Choose "Automatic" from the list presented in the screen that appears. Press the right side of the directional pad on the game controller to move to the "Confirmation" screen. Press the "X" button on the game controller to make the settings active. Return to the PS3's "Home" menu.
    Watching the PS3
    • Insert a Blu-ray disc into the slot at the front of the PS3. Wait as the Blu-ray disc begins to play the video content on the video projector from the PS3 through the HDMI cable.
Please don't forget to rate my answer...I really appreciate any ratings you done..
Thanks for using fixya..
Jul 16, 2011 | Hitachi 37PD5000 Television
Will not play any ps3 games or movies
The PS3 has a special Recovery Menu, which you can access in the following way:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
From the above select option "Rebuild Database". After PS3 has executed this DB rebuilding operation, the disc games will be visible again in the menu.
Thank you
Jun 04, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: the games play only in black and white since I hoo...
You can try the steps below. Its from PlayStation Forum:
1. Turn off Playstation®3.
• Restart System: Restarts the PLAYSTATION®3 System.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• System Update: Update the PLAYSTATION®3 System
If the above steps still does not solve the problem, then I think will have to update your Ps3.
Update your PS3 (in the settings menu the 1st option).
Go on the internet browser on the PS3 then go on the menu press triangle then on one of them there are delete cookies and the delete the others as
well as cookies.
You could also try this as well: put the PS3 on then press the eject button (with no disc in) then hold it and switch the PS3 off at the back with your finger on the eject button still holding it, then put it back on and the fan test should be working this may cool it down. It might be over heating.
But if your problem is not still solved, then maybe you should call sony for further assistance.
I wish you good luck
May 17, 2010 | Sony Playstation 3 (PS3) Console
I wanna know why my ps3 wont play games or show the disk icon
well as cookies.
May 16, 2010 | Sony Playstation 3 (PS3) Console
Not able to play games but play cd and dvd
You can also try the steps below. Its from PlayStation Forum:
well as cookies.
If after trying the above options and it still does not solve the problem, then maybe the lens is weak and that's why it cannot play game Cd's.
I wish you good luck.
Apr 04, 2010 | Sony Playstation 3 (PS3) Console
Screen goes black during game play!
well as cookies.
Mar 23, 2010 | Sony Playstation 3 (PS3) Console
PS3 Menu not comming up on console start up
See if you can restore back to factory settings. Your menu might be corrupted.
Jul 26, 2009 | Sony Playstation 3 (PS3) Console
Wont play when i insert disks only the games on there
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Jun 18, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not play any games
I had a similar problem. My PS3 did not start the disk based games. Those disk based games were not visible in the game menu. I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine.
Jun 07, 2009 | Sony PlayStation® 3 (60 GB) Console
Ps3 won't play read my games
May 06, 2009 | Sony PlayStation® 3 (80GB) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
