Question about Dmm Benjamin Air Rifle
Missing screw i have a screw missing barrel of my 397PA
22 caliber revolver screw that holds the ejector to barrel is missing where can i get a new one
For older guns, the link below is a good place to start. With the Manufacturer and Model# you can search all the parts they have for your revolver. -
Firearm Parts Accessories Military Surplus Numrich Gun Parts
Sep 19, 2017 | The Optics
Mossberg model 88 manual
Open the slide and make sure it's empty....and then close the slide halfway so the bolt is halfway in the eject port. That unlocks the bolt lug from the barrel. Unscrew the barrel take down screw. Remove barrel. If the take down screw is overly tight, use pliers with a leather or canvas padding to avoid scratching the screw. When reassembling it, just tighten it tight by hand. Use no tools. It's not designed to tighten with tools. Hand tight is perfect.
Jan 03, 2014 | Sport & Outdoor - Others
Manual for wearever super shooter cookie press
Instructions hand copied from my old manual
1. Stand motor on flat surface; screw barrel securely into place.
2. Attach flat side of piston onto screw and turn far enough to see 1-2 threads
3. Insert assembled piston/screw in barrel so that notches in piston line up with the ribs in barrel; snap screw into place.
4. Fill barrel with desired mixture, using small amounts at a time and tamping into place with barrel loader; wipe any excess mixture from exterior of barrel
5. Select desired cookie disc or tip; place on filled barrel
6. Attach cap to barrel; tighten securely in place. Note: machine may be operated with barrel partially filled
Note: If cookies do not cut off properly even though dough consistency is correct, make sure the 3 feet of the barrel cap touch the cookie sheet each time in order to form the cookie. As the gun is lifted, the flow of dough is cut, forming the cookie on the sheet.
Nov 23, 2012 | WearEver Wear-Ever Super Shooter Electric...
We are missing the inserts to screw in the side rails, can I find something locally
If by insert you mean the round things that go up in the holes and a bolt screws into them to keep the bed together, then yes. They are called Barrel Nuts. Available mostly in USA standard sizes, most commonly a 1/4 20 ("quarter twenty" for 1/4 inch wide with 20 threads per inch) at any Lowes. Take your bolts with you for a length measurement and buy new bolts that match the new barrel nuts. Should be fine, just dont overtighten or you will crack the wood. Good luck and if I got INSERT wrong let me know.
Mar 09, 2011 | Evenflo Jenny Lind Crib
The dryer throws hot air, but the barrel inside will not go around
it is either your belt broke, the rollers or your motor burnt out. you will have to take a screw driver and remove the front panel. Make sure it is unplugged. one the screws are removed you will have to pry the top up, it should pop off easy if not then you missed a screw. Lean the lid all the way up an look to see if the belt is around the drum, shold be in the middle and tight.
Jul 20, 2010 | Roper REX4634KQ Electric Dryer
The trigger does not work
Check tiny allen head grub screw has not loosened on bottom trigger button and is catching on housing, otherwise one of the o-rings is missing off trigger plunger or piston. Carefull of spring behind trigger button when loosening allen grub screw. You will find the plunger behind trigger button.
Apr 22, 2010 | Ingersoll Rand Ingersoll - Rand Ir 117...
MSZ A12NA the inside fan is making noise how do i
It's a quite complicated procedure but i'll try to describe as best i can.
Below the air outlet there should be a couple of screws. They may have small tabs over them (purely for aesthetics!).
If you lift up the filter cover, remove the filters and remove filter cover (trying carefully not to break it... darn plastic!) there may be some screws above the air outlet.
Remove the fascia cover starting from the bottom. Pull it out over the louvre in the air outlet. It will be clipped at the top near the back. These can be difficult to undo. Once that's done, remove the cover.
For the next bit, make sure that the power is turned off to the unit. (power cord unplugged, isolator turned off or c/b off depending on power source)
Undo the screws on the power box.
Undo the screws on the drain tray and off the left side of the evaporator coil. (Big finned section of pipework). Make sure you support the evaporator coil as it's only connected with copper pipes which bend/kink fairly easily.
You'll need to pull the coil out a little (not too far) and take off the left hand rubber 'bearing' as such from the indoor fan barrell.
On the right hand side of the unit you'll find the fan motor (which is held in by the power box) There should be a grub screw that holds the fan barrell onto the shaft of the motor. This is usually undone with an allan key but have seen them with phillips head screws also. This grub screw might be in a few different places. It might simply be on the right end of the fan barrell or sometimes the righthand column of blades is missing a blade and the grub screw is accessed by putting allan key/screwdriver up missing portion. You only need to loosen the grub screw, not remove it.
Once loosened, the fan barrel can be pulled off the motor shaft and removed.
Once off, you can inspect it for obstructions or broken blades etc. To reassemble is just the reverse of these instructions.
Just a few things to note:
1. Be careful of the evaporator coil not to kink (or break!) the copper pipes or your a/c won't work properly.
2. The drain tray may have water in it if the a/c has been operating recently.
3. Make sure the power is off before pulling off the power box.
This can be a very difficult task and I would recommend having an assistant to help with holding stuff.
Hope this helps!
Jan 17, 2010 | Mitsubishi MSZ09UN Air Conditioner
I HAVE A MERCEDEZ 190 AND THE KEYS ARE NOT TURNING IN IGNITION BARREL NOW THE STEERING IS LOCKED ALSO I HAVE TAKEN OUT IGNITION BARREL WITH STEERING COLOUM. i WOULD LIKE TO DISINGAGE THE IGNITION BARREL...
it is better to buy a new ignition barrel.it takes a special socket to get the screws out, once the screws are out they do not need to be replaced.buy new barrel,disconnect negative battery cable,disconnect wires from barrel assembly, remove barrel from colum. first take vin# to dealership parts department to get correct barrel assembly, the keys with new assembly will fit doors and trunk
May 19, 2009 | 1993 Mercedes-Benz 190
Missing Babycraft Crib Screws
a few trips to the hardware store will solve this, take a few screws from around the house and find one that will thread into the barrel or whatever is in the frame, measure the lenght and off to the hardware store. home depot has a large selection of specialty screws.
Dec 31, 2008 | Delta Enterprise Versailles 4970 Crib
Mr. Slim MS12- Mold Problem
I have had to clean mine on a yearly basis. On mine once I have the cover off, I can remove a couple more screws, disconnect the baffle motor and the drain connection and pull the drain pan off to gain access to the barrel fan. The first time I cleaned it with a small bottle brush and bleach water. I scrubbed each fin individually, alot of work! I used a pressure bottle(for the garden with wand) to rinse the fan. Then the next year I used a Shark Steamer to clean and kill the mold, still alot of work but easier then scrubbing. I am going to try rinsing it more often with white vinegar to kill the mold.
Jul 26, 2008 | Mitsubishi Mr. Slim MXZ30TN Air...
Dmm Benjamin Air Rifle Logo
43 people viewed this question
Top Dmm Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Dmm Boating Expert? Answer questions, earn points and help others
