Question about Parrot 3000 Evolution Advanced Bluetooth Microphone Car Kit
My parrot doesn't mute - Parrot 3000 Evolution Advanced Bluetooth Microphone Car Kit
Parrot 3100 how to un mute
If the kit is stuck on mute you will need to power cycle the kit by diconnecting and waiting 5 mins.
Feb 07, 2014 | Parrot 3000 Evolution Advanced Bluetooth...
How do i wire a parrot to my 07 plate jeep patriot
how have you wired it up, have you used the correct lead? on some jeep cars the sound only travels down the rear speakers and the amp in the boot splits the sound. you will also need to radio on for the parrot to work.
Dec 02, 2011 | Parrot Par Ck3000 Evolution Ck3000...
My parrot handsfree kit keeps muting itself when i answer a call do you have a solution?
This will need a software update, you will need a laptop with Bluetooth and download the update manager from Parrot.com. otherwise you can also find all parrot engineers on the web site.
Oct 17, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
I have an audi a3 2005 but my CK3100 wont mute when taking calls??
Has your 3100 ever worked correctly since being installed? Can you give me more information about how it was installed (professionally or by your self)? Often times when these are installed the mute wires get connected (Mute 1, 2, and 3). These are unnecessary and will often cause problems because many stock radios don't have a dedicated mute wire. If you are able to get to the wiring disconnect and tape up the mute wires. Did that solve the problem? If not and if this also came on after a time where the Parrot worked correctly, it could be the blue box or the mute cable (the one with the wires that go to and from all the speakers with the black box on it) have gone bad. I've installed many of these without issues. I've also had to replace brand new ones after people installed them and connected the mute1, 2 or 3 wires. If those mute wires are connected to the wrong wire in the vehicle it can allow current to flow into the device causing it to damage itself damaging itself.
Let me know if this has been helpful
Ray
Mar 01, 2011 | Parrot SA Parrot Ck3100 Lcd Handsfree...
How to wire my parrot ck3100 into a sprinter van can u give me the wiring diag as i dont have any connectors on my parrot kit as its from my old car im having trobule with the mute wires and speaker...
First, you will have to know if the vehicle has a facra or an iso norme build in it.
If it is a Facra, the wires to wires install is still possible but complicated and will necesarly need to get the diagram. Especially if the vehicle has an amplified system build in it. Or maybe optic fiber somewhere in the vehicle.
The vehicle has maybe an mute included into the autoradio, then the hot question you have is about the existing cable harness existing.
In that case I will advising you to get in touch with the manufacturer of the kit to get informed.
Aug 03, 2010 | Parrot SA Parrot Ck3100 Lcd Handsfree...
After using the parrot to make a call on Friday, my radio has stayed muted. Normally, after ending the call, the radio comes back on after a few seconds. CDs also are playing, but are also muted.
it sound like the software has locked u you will need to have new software put into the box, this can only be done using an update cable. try parrot.com and find you nearest engineer.
Apr 26, 2010 | Parrot Par Ck3000 Evolution Ck3000...
Parrot Glicches
sometime, it my be in relation with the install.
Just a simple question, did you install it by yourself? if yes, did you connect the mute cable of the kit? cause if you disconnect it and try to make working the kit and see if the mute is working may be the explanation. signal treatment.
(except trouble of the kit), after a while plugging on a 12v dc only can be the explanation. Do you have the message "good bye" on the display when you switch off the ignition key? If not, that could also be due to the fuses inverted to the vehicle between the 12 dc and the 12 ignition. Then you just have to inverse fuses.
Feb 11, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
Mute the audio system when
yes the yellow wire is mute and needs to be connected to the mute on the back of your radio.
Nov 06, 2009 | Parrot SA Parrot Ck3100 Lcd Handsfree...
Parrot 3000 Evolution Advanced Bluetooth Microphone Car Kit Logo
Top Parrot Cell Phones Experts
iPhone Technicians
iPhone Technicians
Level 1 Expert
Starnley Johnwells
Starnley Johnwells
Are you a Parrot Cell Phone Expert? Answer questions, earn points and help others
