Question about Sharp R-820B Convection/Microwave Oven
Grey Painted Area Inside Microwave Has Flaked Away
The Paint Under The Glass Turntable Has Flaked Away And The Steel Is Visible, It Is Causing The Glass Plate To Slip And Come Off The Plastic Turntable With Little Wheels
tiway1
  • 100 Answers
SOURCE: replace glass turntable for Sharp microwave
You can order it from...
www.microwaveglasstrays.com
This link will take you directly to the tray you need - Sharp part # NTNT-A084WRE0
Posted on Jul 06, 2008
EwingElect
  • 276 Answers
SOURCE: Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Posted on Mar 25, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: rust under turntable of microwave can i paint it?
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Posted on Jun 02, 2009
milten1
  • 1304 Answers
SOURCE: Roller Stay for Sharp Carousel microwave oven
u can try www.partstore.com
but the tray roller is pretty much univeraql if you have problems finding it for that model alost any sharp tray roller will fit the unti
i just grabbed one out of the dump for my personal un it and it works fine
Posted on Oct 09, 2009
  • 4090 Answers
SOURCE: can a microwave door be painted on the inside as
NO! This is baked enamelo finish and any paint you put on it will burn off or catch fire. Buy a new door panel
or get a new microwave from Cash Converters or whatever secondhand or Pawnshop as these units are so cheap now that one can be picked up for about $50
Please rate our help++++Thanks for using FIXYA
Posted on Oct 11, 2009
Panasonic Inverter microwave, paint starting to flake under the ring.What can be done?
dont ever in future buy a microwave with a painted interior as it will always peel.......better to buy a stainless steel one.i don't know if there is a special paint you can buy but if you look on the internet you will find one.
Oct 24, 2017 | Panasonic Microwave Ovens
I have a Goodmans Microwave ME20W in perfect order except someone has misused it and the paint under the rotating plate is blistered causing the oven to crackle in use. There is also one small area of...
Yes they can be cleaned. prepared and painted with enamel paint.
The reason the paint comes off is usually due to condensation as the oven is left with the door closed after use.
Mar 14, 2011 | Microwave Ovens
What kind of paint is best for the bottom interior of a microwave (under the turntable)
The area will first have to be sanded smooth and cleaned and dried thoroughly.
If the cavity metal of the oven is cracked or split, you can use a small amount of steel-based epoxy such as JB-Weld the crack or hole.
Once that dries thoroughly, you can sand it smooth.
Then you can apply some high-temperature appliance paint, available from places like your neighborhood hardware store, Wal-Mart, Lowe's or Home Depot.
It is important to do this right away as bare metal will cause arcing. Joe
Feb 18, 2011 | Microwave Ovens
Microwave turntable guide
it could cause the magtron to arc...becaus the exsposed metal...you can purchase the paint for the inside color of microwave...sand around area..wipe out,,,unplug microwave first....leave door open ,spray it ,let stand couple of hours or 1 day...hope this helps...michael doctorr airr appl.repair 843-384-8474..call if need assistance..good luck
Mar 26, 2010 | GE JES1851 Microwave Oven
White bottom panel inside the microwave is peeling in two spots. What can be done if anything?
affected area would need to be sanded and re-painted with microwave paint. repairclinic.com sells the paint
Feb 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave oven has are rust spots;can I paint over them?
Yes, you can paint over the spots and no, it's not dangerous. I'd let the paint thoroughly dry before using the oven -- it could otherwise cause paint to buckle/ripple/etc.
May 03, 2009 | Microwave Ovens
My microwave is rusting inside. mainly the area where the turning wheels meet the base. I have sand and painted with microwave paint but after a few weeks the paint area around the wheels is rusting again.
try the microwave touch-up paint again but this time clean the spots you sanded with rubbing alcohol. also make sure the rollers turn freely
Jan 31, 2009 | Microwave Ovens
Enamel under the glass turntable has flaked off
This is due to spills, accumulated moisture from steam / condensation, or both.
It can also be worse if your internal cooling fan is not running, or if the vents or filters are blocked or clogged.
Since the the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and then dried thoroughly.
Let it dry overnight with the microwave door open.
Once that's done, you should occasionally look for accumulated moisture on the floor of the oven and keep it dry.
The model number tag should tell you where it was made.
Jan 07, 2009 | Magic Chef MCB780W Microwave Oven
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-820B Convection/Microwave Oven Logo
156 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
