Question about Dometic Refrigerators
Refrigerator stops cooling
It works for a while,then stops. it also stoped when I turned the propane on.
SOURCE: Our Danby propane refrigerator has
Having a simular problem; try changing your regulator on your propane tank. I'm try to find a new thermostat myself. Good Luck!
Posted on Aug 03, 2008
SFroese
  • 141 Answers
SOURCE: insufficient cooling
Sounds like an absoption fridge with a blockage or leak.
Just to be sure.... How do you know the boiler is working? If it is hot to the touch, then is is working, otherwise it is not.
If it is working (hot to the touch), then it should be the same temperature to the touch as the fridge coils. If the coils are much cooler or much warmer than the burner tube, then you have either a leakage or a blockage. Either way, you need to replace either your cooling unit or entire fridge.
If the boiler tube is not hot when the fridge is turned on, then you have a blown fuse or faulty control board. Or you have no power going to the fridge.... :)
Posted on Sep 06, 2008
bravehrt87
SOURCE: refrigerator and freezer not cooling
Check for frost coating back panel in freezer-lower half-if frost is visible, you have a defrost problem, and air channels behind panel are blocked with ice/.frost build up.
Posted on Jan 07, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Freezer stoped cooling
Check the relay on the compressor. It sounds like the relay is not kicking on the Compressor like it shorted out. You can check it with a multi meter, it should be 110 volts or more if there is less or if you see a burn mark replace it. They are about 30 dollars at a local appliance shop
Posted on Apr 17, 2009
  • 906 Answers
SOURCE: Danby Propane Refrig-- Low Cooling Output
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
Danby DPR2262W propane refrigerator stopped cooling
OK-to make this short-you either have a boiler tube blockage or Hydrogen diffusion.If your cooling unit quit suddenly,you more than likely have a boiler tube blockage due to precipitation of Sodium Chromate.If your cooling unit gradually quit working it's Hydrogen diffusion.This process is not easy to understand,and I won't bother you with the details as to why.By the way,burping is a myth,it dosen't work.If there is a blockage in your cooling unit turning your refrigerator upside down won't dislodge it.Danby dosen't make stand alone Propane refrigerators anymore,and since the cooling unit is foamed into the box,it's a throw away refrigerator.You will have to get a Servel RGE 400 made by Dometic.It's the same size as the Danby and I have those for a very good price.Go to: www.marvinspropanerefrigerators.com
Aug 20, 2012 | Danby DPR2262 Top Freezer Refrigerator
Refrigerator does not get cold. The freezer works fine, but the fridge only gets slightly cool.
normaly the fridge has its own thermostat to keep the tem right, if this thermostat has stoped working it will do one of two things,,, freez every thing up as it wont turn off the compressor or will just stop working as it wont turn on the compressor,,, try turning up the thermostat first,
Nov 19, 2009 | Hotpoint Refrigerators
Refrigerator stoped cooling
Ok, if the unit compressor will not run and just clicks on and then off, this will confirm a low charge state ad you will need to recharge this unit. the refrigerant level is low.
Purchasing a recharge kit and recharging the system will fix this issue.
May 15, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kemore Refrigerator MODEL# 2535808789A is not cooling.
Thank You for having your model number ready, Could you remove the grate on front and bottom of refrigerator to expose the defrost timer. In the opening on front turn the timer slowly turn clockwise until you hear a click or change in operation of refrigerator. Let me know, Sea Breeze
Mar 21, 2009 | Kenmore Refrigerators
Refrigerator and freezer not cooling
the relay on your compressor is more then likely the problem it is on the left of the compressor
Jan 07, 2009 | Whirlpool ED2FHEXN Side by Side...
Our Danby propane refrigerator has given us sterling service for about five years, but it has suddenly stopped cooling in the refrigerator box-the freezer still works. Any clues?
Apr 17, 2008 | Danby Refrigerators
Refigerator leaked water slightly then stoped cooling
Yes try to turn with a screw driver if possible. If it start working replace timer. If not it can be low on freon you would see frosting but no cooling.
Jan 07, 2008 | Magic Chef CTF2125 Top Freezer...
Refrigerators Logo
13 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
