Question about Philips HTS3100/05 Theater System
No sound video ok but no sound
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
In Samsung tv complaint<br/>in first time tv working in normal and after sometime picture is blinking and slowly no pictre. that time sound is also ok.<br/>after that am am change the capa
Check its solder terminal at the CRT board [Filament voltage]. It sounds like the filament do not glow after some time due to a loose contact at the CRT base connector sockets. Check it.
If this does not help, check the ABL circuit for any open resistor.
Oct 25, 2014 | Televison & Video
Have a Sony EVC100 Hi8 deck . Video is playing ok.
Bad secondary sound head, needs to be replaced.
Oct 02, 2013 | Sony EVC100 Hi8 VCR
My camera olympus fe 115 when i take the video it ok but no sound
It's not suppose to be sound.
That's how it was designed and it's in the user's manual.
Mar 20, 2009 | Cameras
Toshiba 50HP66 Plasma TV
Found that video 1 and video 2 switching does not work. The switching IC was HOT!. Then found a third video input works but no sound. Hooked -up sound output of DVD player to amplified loudspkr and it works, I hate to throw away a 2 year-old plasma TV when TV and cable still works.
Thanks for the offer anyway.
Mike
Oct 12, 2008 | Toshiba 50HP66 50 in. Plasma Television
No sound on olympus sp-55ouz video playback
To turn on audio, go to the video setting. Hit the menu button. Hit ok to select the camera menu. Go down to the picture of the microphone and hit ok again. Select on and then hit ok again. Your sound should be set. Hit the menu button twice to get you back to taking videos.
Jul 13, 2008 | Cameras
I get no picture on samsung pck5315r TV
no picture & sound ok as sound is there means your power supply &high voltage section is ok problem is in video section 1 crt is glowing or not if not check its supply. 2 check crt base or any connector for loose 3 check supply to video & crt base(g2) 4 check for video signal is coming to video sectuon from processor ic. 5 loose print if any. hope this will help
Sep 30, 2007 | Samsung PCK5315RX TV
Zenith big screen
sound is ok means power supply is ok. as there is no picture there is a problem in video or luminance section. 1 check chroma ic supply 2 check signal line to video section 3 loose contact in video section 4 crt base loose 5 crt supply 6 no supply to g2 7loose contact in brighness line
Sep 16, 2007 | Televison & Video
Philips HTS3100/05 Theater System Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
