Question about Sharp AR-407 Copier
I have a Sharp AR 407 copy machine and when I turn it on it displays an F1-11 error code. Please help me. I work for a nonprofit and we really can't afford to pay someone to fix it. Thank you!
  • curtisyates2 May 03, 2010
    what does it mean when the display tells you to close the finisher unit and finisher covers
    Scholar:
  • Sharp Expert
  • 120 Answers
The problem is in your finisher and the quickest solution to get your copier running is to unplug the finisher and move it away from the copier. Take a tray off the finisher and put it on the copier where the paper comes out. (If the paper comes out too slow and causes a misfeed the tension springs need to be put back on over the exit rollers in the left door, write if you still have trouble)
The Engrish service manual sayeth:
F1-11: Finisher 1 pusher motor trouble/Finisher 2 boomerang rotation abnormality.
What this doublespeak means is that something is blocking your motor's ability to function when it goes through its' power on self test. First thing you should never do is put anything near, around, or under the finisher. I went on a lot of calls for F1 errors and either unjammed a finisher from the wall or unstuck a toner or paper box from under the tray. Next thing is to open the front door, move the plate from side to side, and look for bits of paper wedged in anywhere. Spray any photoelectric sensor you see with a can of air. And check those squishy orange rollers and see if they're swollen. Could be you have a dead motor, which would be at the rear of the finisher or inside one of the trays. Good luck!!
Posted on Jul 09, 2009
Error code H4 appear on display when voltage low in photo copier machine sharp AR-a61
in order press P * C * or # * C *. the machine will go into diagnostics. Then enter the number 14 as if making 14 copies. Then enter 1 and press start. That should reset your machine.
PLEASE let me know if this fixes it.
Aug 19, 2010 | Sharp AR-M160 Black and White Copier
Sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
Apr 28, 2009 | Sharp AR-407 Copier
Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Apr 11, 2009 | Sharp AR-407 Copier
F2-02 Error on Imagistics ZB35 machine
Sharp AR-5620N getting f-2 error. What is the solution
Mar 03, 2009 | Sharp AR-M237 Copier
Sharp AR-5127 H2-00 code reset
Sharp Fuser
H2-0 Fusing unit temperature error
H4-0 The fusing unit doesn't heat up.
***ALWAYS DISCONNECT POWER WHEN WORKING ON MACHINE***
You have to reset fuser errors with simulation 14. Push P * C * then 14 then Start (the button you use to make copies) and it should reset the code. If not then replace the fuser.
SM 5-1 should turn the lamp on. If lamp blinks on and off it is the thermistor, if it does not it is the lamp, but check the contacts on the lamp/fuser -- they have been known to erode.
Also check thermal fuse, if defective replace.
Feb 01, 2009 | Office Equipment & Supplies
I have Sharp AR-407 Grayscale Copier and i got the problems in it . it showing me the E7-11 code . i dont know how to solve this problem . can any one help me to solve it thnx
this is ccd white correction , clean the opitus really good and under the plat on the right side make sute there is no condisation or dirt on white plate
Jan 14, 2009 | Sharp AR-407 Copier
Sharp AR-5316
Never heard of an F2 on that machine. But give this a try.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Mar 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-407 Copier Logo
358 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
