Question about Akai PT61DL34 Television
Where is the system reset buttone on dlp 72" - Akai PT61DL34 Television
Where is Fan #1 on a Samsung 67" DLP HDTV
There are 3 fans with this set. Two of them are at top [inner side] and one in the light engine [inside the light engine]. There is no such button to reset the fan only. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done
Nov 03, 2014 | Samsung HL-67A510 67" DLP HDTV
Bp96-02069a - 72" Samsung DLP, 4 yrs old, purchased at Costco. Color Wheel needs replacement but part discontinued with no apparent replacement?Any Advice or is the $3000+ TV trash already?
You can see if one pops up on EBay or look for a parts set on Craigslist. I personally would sell the set for parts. I'm biased, not a fan of DLP's
Nov 11, 2013 | Televison & Video
Where is the reset button on a mitsubishi dlp 73' tv?
  • Open the front panel by pushing on it. Pressing on the panel releases the lock and allows the front panel to pop open slightly. Pull the corner gently to open the panel completely.
  • 2
    Use a pointed object, such as the sharpened end of a pencil or the tip of a paper clip, to push the "System Reset" button.
  • 3
    Wait about one minute, or until the green LED light on the front panel display stops flashing.
  • 4
    Turn your television back on once the green LED light turns off.
    this is procedure for most mitsubishi dlp.
Oct 15, 2013 | Televison & Video
Samsung R4266w turns off automatically. I've
Rest the lamp hour meter
  • 1 Press menu on the DLP's remote.
  • 2 Scroll down the list to "Timer."
  • 3 Press "Enter" on the remote, then "Reset." Press "OK" to complete the process, and "MENU" to exit the menu.
Service Level Reset
  • 1 Turn off the DLP with the remote.
  • 2 Press a pre-determined button sequence on the remote control to access the factory reset option. These sequences are found in the owner's manuals of the various DLP televisions, or in the "Support" sections of the manufacturers' websites. Scroll to the "RESET" option on the menu to reset the bulb timer.
  • 3 Press a factory-determined combination of buttons on the remote and front panel of the individual DLP display to reset the bulb timer without entering a menu.
Aug 14, 2011 | Samsung Televison & Video
3com 3crwdr100a-72 how do I reset the router
For 3com type of routers, you must connect firstly to 3com setup, By:
First: open your browser and type 192.168.1.1
Second: you will find adapter setting and reset it, it all depends upon your router's software.
Third: the easiest way is to reset it from the small button in the back of your router.
Dec 14, 2009 | 3Com Wireless LAN Access Point 7250...
My 72 inch samsund dlp tv has a ''check fan no. 2 message and the stand by/temp and timer lamps are blinking. both fans, sensor, balast, power supply and main board have been replaced
Hi,have you tried replacing the lamp? if tv is between 2-4 yrs thats what it could be,also reset tv by unplugging it wait 5 min and plug it back again.
Sep 30, 2009 | Samsung Televison & Video
Samsung DLP 72inch, recurring loud pop then fuzz for 3 seconds
I pulled out the Lamp, cleared the dust inside with one of those air blowers and returned the Lamp. That seems to have fixed the picture problems I was having.
Jul 07, 2009 | Samsung DLP HL-P5663W 56" TV
Garmin gps 72 not aquiring satelites
Press POWER ON and PAGE buttons at startup and leave for 20 minutes to initiate
Nov 09, 2008 | Garmin GPS 72 GPS Receiver
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
Akai PT61DL34 Television Logo
20 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
