Question about Farberware T490C 1500 Watts Toaster Oven with Convection Cooking
How can toast chicken
How can to do toast chicken
Help my toaster doesn't toast my eggs
Your toaster may not be intended to toast eggs.
Oct 09, 2016 | Toaster Ovens
Rotisserie squeaks
That is perfectly normal, enjoy your chicken Sally.
Oct 24, 2014 | Toaster Ovens
Why won't my calphalon toaster oven toast top of bread? Why?
If both the top and bottom elements are working then you may need to re-position the rack closer to the top element for even toasting. If there is only one rack position available then you may need to flip the bread and toast it twice.
Oct 06, 2014 | Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
I didn't get a manuel and the toast does not go
The Instruction Manual for your West Bend 78224 QuickServe Toaster is available here:
http://www.westbend.com/supportdata/L5670-QuikServeToaster-ALL.pdf
Uneven or ragged edges on your toast can catch on the toast rack and prevent it from siding through on to the serving tray. Trim off any ragged edges.
Thank you for using FixYa!
Sep 15, 2011 | West Bend 78224 Toaster Oven
How do you set the delonghi convection toaster oven to cook chicken nuggetts?
Try this:
Thermostat knob - Toast/ broil
Time - 18 minutes
Wire Rack Position - Upper
Turn after 10 minutes.
For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
Regards.
Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
What should one do if the toast in oven catches on fire? please respond.
Switch the over off at the wall and unplug it first. Remove the burning toast with steel tongs or something similar that wont burn you and place toast in sink in water to extinguish flames if there are any
Your oven should be okay to use again under the following circumstances
  1. The toast was simply left in there too long, hence it caught on fire
  2. There was only smoke or a very small flame and the interior of the oven was not blackened
If in doubt or the flames were of reasonable size, or the interior of your oven has been blackened with smoke, do not reuse the oven without getting it checked over by a licensed electrician. There is a risk that you may have overheated and melted some of the wiring.
May 10, 2011 | Black & Decker Toaster Ovens
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
B&D TRO200 Toast-R-Oven bake function does not work
its not repairable at any price . you have a bad thermostat , its soooooo common with this oven . asprie who makes this oven in china, then inports it with black & deckers name on it . has not made any parts for it , not even a wire shelf or a knob .....when something happens to it , you toss it in the trash .....
Mar 07, 2009 | Black & Decker TRO201 1550 Watts Toaster...
Never received the direction book.need one
Go here and download the pdf file. You'll need adobe.
http://personafile.com/Black-&-Decker-Toast-R-Oven-Broiler-TRO600-TRO603-TRO604-P0508755200417.htm
Dec 12, 2008 | Black & Decker TRO603 Toast-R-Oven Toaster...
Farberware T490C 1500 Watts Toaster Oven with Convection Cooking Logo
Top Farberware Toaster Ovens Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Farberware Toaster Oven Expert? Answer questions, earn points and help others
