Question about Hearthware Kitchen Appliances - Others
Regal 2765 parts schematic.I HAVE A NUWAVE 20008.I SET THE POWER LEVEL AND TIME,PUSH START AND IT SHUTS OFF IN 2 SEC.THE FAN WORKS,THE HEATING ELEMENT HOT IN 2 SEC
SOURCE: Shutting Off Prematurely
may be highvoltage circuit or high voltage diodes, or mains power problem, check the control unit.may be magnetron..
Posted on Sep 25, 2007
SOURCE: Panasonic NN-C994S stop 2 sec. after I press Start.
Sounds like the power inverter
Posted on Apr 18, 2008
  • 9 Answers
SOURCE: dryer heats up but won't turn
Perhaps you have a broken drum belt
Posted on Jun 24, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1028 Answers
    SOURCE: Kenmore Dryer Model 110 Heating Element & Thermostat
    believe that model has a relay under console..pull console end caps off remove screw on each end roll console back..if your model has an electronic bd it also has a heat relay it will be the one with 2 large red wires.. a quick ck would be to unplug power remove the red wires and tape bear ends together pug back up turn on dryer if it heats unplug and exchange the 2 relays the one with the blue wires is the motor relay and is same as heat relay try again if motor fails to start bad relay if motor starts bad control bd
    Posted on Aug 10, 2008
    How can I turn it on?
    Nuwave 20326 Pro Digital-Controlled Infrared Tabletop ...
    www.amazon.com > ... > Slipcovers > Slipcover Sets
    Amazon.com, Inc.Amazon.com - Nuwave 20326 Pro Digital-Controlled Infrared Tabletop Oven, Black by IBC - Hearthware, INC - ... by Ibc Hearthware ... or ventilation needed; dishwasher-safe parts, Extender ring, cooking rack, baking pan, manual, and recipes ...
    Owner's Manual - Home Depot
    www.homedepot.com/.../9999807b-2e22-42d5-8cea-1...
    The Home DepotManufactured by Hearthware Home Products, Inc. .... turn off the power before removal, or if digital, push .... Directions for Nu-Wave Oven Manual Control Dials ...THE MANUFACTURER WARRANTS - The infrared cooking system includ-.
    Jan 26, 2016 | Hearthware NuWave 20326 Pro...
    Why won't it start?
    It should automatically restart.....BUT what happened is that when you unplugged it, you cut off the blower at the same time you cut off the heat element(s). The way it is supposed to work, is the thermostat cuts power off to the elements and the fan continus to run for a per-determined amount of time to remove al the heat from the elements. Then another 'fan control switch' shuts off the fan once the 'residual' heat is removed from the heater. Without that 'cool down' cycle, the hot element had enough 'residual' heat in it to trip off the 'thermal overload' in the circuit. The 'thermal overload'... or...'hi limit'...or...'hi temperature control' is resposible for shutting power off to the element(s) in the event that the blower fails.
    Sep 24, 2015 | Heating & Cooling
    Why won't it start?
    I copied and pasted this answer from your other question as I thought it was the same one Sherry.... Hope it helps you.
    When heat is on the fan never shuts off until just before the heat cycle starts...cools the house off rather quickly therefore heat runs more..when the A/C is on the fan shuts off between cycles how
    The heat runs the blower until the heating elements cool to a specific level, to get all the heat out of them. The switch wears out and or sticks (called a Limit Switch). if you have a handyman he may be able to lube it w/electronic lube spray but it may beworn out. $30 part, plus service call.
    Oct 17, 2014 | Heating & Cooling
    I SET THE TIMER ON MY NUWAVE OVEN I TURN IT ON IT TURNS ITSELF OFF
    I looked at one of these today with the same symptom. Set a cook time, turn it on and the fan starts for a second and turns back off. When you take the cover off of the unit you will see a fan. On the winding of the fan is a thermal switch. I found a bad connection on one of the wires to that switch. It threads into a couple of cutout areas in the plastic on either side of the fan windings. It is there to open if the fan stops working to prevent the thing from melting down with the heat from the element not being blown downward. The wires have a heatshrink around them, so you will have to cut that away put in a new piece of shrink, re-solder the connection, then pull the shrink over it again and shrink it down. Worked for this one and I hipe it helps you too. Good luck.
    Jul 12, 2012 | Hearthware Home Products Nuwave Pro...
    Dv6704nr wouldn't boot
    Sooner or later all PCs to that, just like cars, wont start.
    DV6-704n? came new with VISTA in 2011 .
    this is a lap top, there is no schematic at that level. (a secret it is)
    won't boot (but many things must be ok before boots happen)
    IT STOPS, you mean it shuts its power off after power on by itself
    sure that can be a power problem and is FIRST
    so is a black screen all the time,
    my guess, it self powers OFF and cant get in to BIOS.
    BIOS DEAD TOO? Esc , BIOS pages, or any BIOS pages good?
    all PCs shut off for overheat, as fast as 3 seconds too...
    1: does it run on a/c only, battery out.
    2: is BIOS alive (this is first after running on A/C power only, does it> run BIOS now???? the fan for sure runs, if power is there
    is the coin cell dead, ?
    3: full of dust and CPU overtheats or heat sink loose does this.
    4: flash codes. at power on?
    5: a/c power pack work with main battery out? yes/no.
    try a new A/C pack, some get weak and does this. easy.
    most HP packs are 19vdc on the 2 wires.
    if not at spec. 19v (near) then its a bad pack or wrong watts pack used. The 19vdc is really #1 , it must be good or it will fail hard.
    May 23, 2017 | HP Pavilion dv6704nr Notebook
    The fan works but the element does't heat. I also try everything I knew to try and get it to work.
    ihave same problem c.s told me i would have 2 buy dome for 35 & s&h 15 i am currently looking for element let me know if u find fix
    Apr 25, 2011 | Hearthware Home Products Nuwave Pro...
    Hotpoint Dryer Heater stays on when door is opened
    Strange. Heaters usually shut down with the spinning drum when door is open. If you check the schematic for unit you can check to see if in fact this is correct operation. Attached site usually has schematics for appliances. You might want to check. Search Over 2 1 Million Appliance Parts
    Sep 01, 2017 | Hotpoint NVL333EY Electric Dryer
    Dryer takes a long time to warm up. It drys in 2 hours and does not shut off automatically. Maytag series 200
    To make things properly, voltages to heating element should be tested, but that is a job that must be done by a technician.
    Test first the heating fan. If it is not working replace the fan assembly.
    Replace the heating element if that does not solve the problem replace the control board.
    You can find schematics and diagrams by entering model number here.
    Feb 18, 2009 | Maytag PYE2300AY Electric Dryer
    Kitchen Appliances - Others Logo
    Top Hearthware Kitchen Appliances - Others Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Are you a Hearthware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
