Question about Hilti TE 70 Hammer Drill Performance Package
My hilti wont work - Hilti TE 70 Hammer Drill Performance Package
IT WILL NOT COME ON
Please check the the manual on page 15
https://www.us.hilti.com/medias/sys_master/documents/h29/9077506998302/PUB_5135115_000_APC_RAW.pdf
Oct 10, 2014 | Hilti TE 70 Hammer Drill Performance...
Hilti TE 905 AVR wont hammer
sounds like it needs a rebuild kit. Hilti.com for parts or to contact Hilti to see if you can get parts. It will also have the parts breakdown.
Feb 21, 2014 | Drills
Hilti te 56 combi hammer not working
The gears inside that engage the chisel points to move back and forth are either not alligned properly or are stripped. You'll have to open up the hammer to see what, exactly, is the problem.
Sep 20, 2012 | Dewalt D25330K 2KG Sds Plus Demolition...
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
Hilty TE 12 Hammer Drill Wont Hammer, but will run
Parts are no longer available for the TE12. Be carefull if you try to take it apart yourself. Some of the older models had a lead based grease in them
Oct 26, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
Battery wont charge on new charger
Just return it to a Hilti dealer, they replace everything for free.
Oct 21, 2010 | Hilti Cordless Hammer Drill Sfh 151 A...
I need a new chuck as mine has lost bearings and wont hold a drill bit
I would suggest going to Hilti.com or calling them direct at 1-800-879-8000 for the replacement part and nearest center.
Oct 04, 2010 | Hilti Drills
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Mar 14, 2009 | Drills
Hilti TE 70 Hammer Drill Performance Package Logo
71 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
