Question about LG LMV1813ST Microwave Oven
Trip Circuit Breaker
The microwave timer works, but if I try to cook with it, it trips the household 15 amp circuit breaker. I plugged into another circuit to make sure it wasn't that breaker and it trips it as well just as soon as you press the start button.
    Prodigy:
    An expert who has answered 500 questions.
  • 547 Answers
The circuit breakers may both be functioning properly. What might be happening is that both circuits have other current drawing appliances on them. The circuit breakers react to the sum of all of the currents drawn by all of the devices on that circuit. So, if you have a 15 amp microwave and an 8 amp refrigerator on the same circuit, you would overload a 20 amp circuit by 3 amps.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Posted on May 09, 2016
2 Suggested Answers
  • 6771 Answers
SOURCE: lg microwave oven trips circuit breaker
The magnetron probably has a partial short pulling more current than normal as it runs, the other two items that give trouble is the high voltage diode, "sometimes cracks" to the high voltage capacitor, "usually shorts"
Posted on Mar 30, 2012
Smeg microwave shorting
If it's the circuit breaker in your house or apartment that's blowing, then either you are overloading the circuit, or you have a bad breaker. Check to see what other devices might be plugged into that circuit, and move as many of them as possible to a different circuit.
Apr 23, 2016 | Smeg Microwave Ovens
Keeps tripping circuit breaker
There must be a fairly major issue with your microwave to trip a 20 amp breaker. I would recommend taking it to your local repair shop or replacing it.
Mar 19, 2014 | Oster OGB81101 1.1-Cubic Foot Microwave...
Blowing breaker
In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1. Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2. If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Jan 24, 2014 | Goldstar Microwave Ovens
Tripping circuit breaker
That unit shows that it takes 15 or 20 AMPS to run. What is the breaker amperage on the circuit where it is plugged in? Is the breaker a GFCI? You can tell by looking for the two buttons on the circuit breaker or the outlet.
Jul 18, 2017 | KitchenAid KCMS1555RSS Stainless Steel...
The microwave is making a funny sound when turned on and it is popping the circuit breaker
try plugging it on another circuit with no load (a circuit with nothing els connected) if you have other things plugged with the oven (toaster, slow cooker, etc..) it could trip the circuit breaker as a microwave oven needs a 15 amps circuit to operate properly...
good luck!
Feb 22, 2011 | Tappan Microwave Ovens
Blowing main breaker
I have a hard time believing that the home's main breaker is tripping instead of the branch circuit breaker that feeds the microwave. I suspect it is really just a difference in terms. You should disconnect it and try using in another outlet - preferably one on a different circuit if possible. If the breaker continues to trip; this appliance should be disconnected and either be discarded, repaired or replaced before using again.
If the microwave works as expected (on a different circuit), it may indicate the original circuit is overloaded. Microwave overs are supposed to be installed on a dedicated circuit. This means only one outlet is on the circuit - no other loads (lights, appliances, etc.) are permitted on this circuit. A microwave typically requires 10 Amps or more when on "high" and will require a significant portion of the power supplied by a 15 or 20 amp circuit breaker. There is little unused to power much of anything else. If other appliances go out when the microwave trips the circuit breaker, you should contact an electrician to have a dedicated outlet installed for the microwave.
I hope this helps!
Sep 23, 2010 | Maytag Microwave Ovens
Microwave / Frigidare PLMV
Chek the high voltage capacitor and the diode . If one of them are short there is a chance for tripping the breaker
May 25, 2009 | Frigidaire PLMV168 Microwave Oven
The past Few days the microwave would trip the breaker. today I went to use it and it worked for 30 seconds when I checked what I was heating and turned it bakc on and it would not work
Microwaves that are either built in, a part of the oven, or over the range are on a dedicated circuit by law. This means nothing else could have tripped that breaker but the microwave.
If it has a problem severe enough to trip a 20 amp breaker several times, it is only getting worse each time you reset the breaker and turn it on.
There is a possible chance of fire. I recommend you turn the circuit breaker off and replace the microwave. Is it a plug in, or over the range type?
May 18, 2009 | Microwave Ovens
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
GE Spacesaver microwave trips the circuit breaker
Since power = voltage X current, 1.58kW / 120VAC = 13.166A
So this unit should be fine on a 15A breaker unless the breaker is bad, the wiring or a connection is loose somewhere between the breaker and the microwave, or the microwave's magnetron or high voltage transformer are failing and drawing extra current.
Microwaves should really be on the own separate breaker if at all possible. Plus, the more a breaker trips, the more work out it gets.
Have you measured the voltage at the outlet? If that's off, current and power will be affected. It should be about 110-125VAC.
A good power test for outlet and wiring integrity is a toaster, toaster oven, or hair dryer rated at about 1500 watts.
If it doesn't run and heat steadily, then there may be a problem with the house wiring or breaker.
If it passes this test, the problem is likely in the microwave.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jan 09, 2008 | GE JVM1190 Microwave Oven
LG LMV1813ST Microwave Oven Logo
81 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
