Question about Gateway Computers & Internet
Describe the procedures for accessing support
    Sergeant:
  • Gateway Expert
  • 504 Answers
Create a profile and log in...
Posted on Aug 22, 2014
What is the leveling procedure for initial installation
The installation instructions that came with your washing machine or can be obtained from Sears describe the correct leveling procedure.
Jun 23, 2014 | Kenmore Washing Machines
How to replace batterys
Page 20 will describe how to remove the seat.
P38 and on will describe how to change the batteries.
Hope this helps Pride Mobility Products Corp Product Owners Manuals Specification Sheets
Mar 23, 2014 | Heavyduty Jazzy 1121 Standard & Heavy Duty...
Sensor replacemet procedure
Well the basic and most simple way to describe your answer which is very basic as well, is 1st disconnect your Neg battery cable from the battery then disconnect the pigtail from the sensor and then remove the sensor replace it with the new sensor and install is reverse of the removal. Of course depending on what sensor your replacing the job will be either easy or difficult depending on its location and access.
Dec 29, 2013 | 2003 Ford Taurus
WHEN FRONT DRIVERS DOOR IS OPENED IT LOCKS ALL DOORS AND WHEN SHUTTING IT OPENS , COULD IT BE THE WIRING LOOM IN THE DOOR
The problem you describe is either door lock/unlock actuator(s), or could be wiring to the relays (door lock relay and door 'unlock' relay. The best advice is have this problem properly diagnosed bya qualified/certified Hyundai Service Technician. OR
Go to www.hmaservice.com and register your vehicle by VIN #.. you'll then have access to wiring diagrams, shop manuals, service bulletins, illustrations and procedures, etc
Aug 30, 2011 | 2003 Hyundai Santa Fe
Is there any special tools or requirements for removing and installing a new exterior (drivers side) door handle. Please describe the process. Thank you.
nope, just wind the window down, remove screws around the arm rest, pull panel out from door releasing plastic retainers, slide panel up out of window seal, remove plastic door dust shield , wind window up and you will be able to access handle through the inside of door, remove latch rod clip from handle, remove two bolts that screw to handle and thats it. Of course replace in opposite procedure
Jan 22, 2011 | 1999 Chevrolet Silverado 1500
FIRSTLY, IPHONE 3.1.3 REQUIRES UNLOCKING HOW DO I DO IT.... AND UNLOCKING SOFTWARE FOR FREE IS REQUIRED. SECONDLY, THE CONTACT DETAILS NEEDS TO BE UPLOADED IN ANOTHER HAND SET IS IT POSSIBLE, THEN DESCRIBE...
to unlock your iphone you want pwnag software instructions and download is here go to this link http://blog.iphone-dev.org/
to upload videos you must convert the videos and upload thru itune software
if u like this plz leave comment
Mar 11, 2010 | Apple iPhone 3G
Compaq presario F700. Display screen is garbled and illegable most of the time. Occasionally it will come up perfectly normal and clear but majority of time its a bunch of multi colored lines flickering....
Since the problem you describe is intermittent I would first suspect a loose or shorted electrical connection. To check this you will need to take the computer apart. Step by step photos of this procedure are at http://www.insidemylaptop.com/disassemble-compaq-presario-f700-notebook/ .
Once you have access to the lcd cable you can check its connection and the condition of the cable itself. If the connection is secure and the cable looks good you probably have a bad lcd.
Nov 28, 2009 | HP Compaq Presario F500 F700 and G6000...
Linksys Router doesn't work with new modem
It sure does. Cysco System (Linksys) routers had a series of defective consumer hardware products like the one you describe.
The update of the firmware usually resulted in total failure of the router. Since you described the proper access and programming procedure of your router, I can tell you that it will be necessary to procure an RMA (Return Merchandise Authorization) for your (defective) router.
I have had many instances of the situation you describe, and, unfortunately, you will have to ship the router to the factory for replacement (providing it is still under warranty).
Apr 11, 2009 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
90 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
