Question about Sanyo Heating & Cooling
Flashing light flashing operation light on SAP KV94GJ.
Brand new, connected to new cox cable box, video works great but no sound
if just running HDMI cable try adding audio cables too, check all your volume and mute settings in the system setup.
If you have audio on most channels, but have silence on some or all of your local network channels, you may have the Secondary Audio Programming (SAP) turned ON. Complete the following steps to turn off SAP.
  1. Press the Settings or MENU button on the digital remote.
    Result: The Settings screen displays.
  2. Choose from the following options.
If... Then... Disable SAPdisplays Press the Select button. Choose SAP Languagedisplays Use the left or right arrow buttons to choose the English setting and press Select. PREFERENCESdisplays Scroll to the Language option, select Audio, then select the option labeled Primary or the one labeled English. If the above quick fix doesn't work, there may be a problem with MTS, Stereo, or another SAP issue. Try the following:
  • Verify in the program listing guide that the program has MTS, Stereo, or SAP features.
  • Check to see if the MTS, STEREO or SAP light on the TV or VCR is on.
If the light is not on, try the following:
  • Push the MTS, STEREO, or SAP button on the TV or VCR.
  • Adjust the fine tuning on the TV set to restore the stereo or SAP.
http://www.cox.com/residential/support/tv/article.cox?articleId=81da8760-5c47-11df-ed4d-000000000000
Jan 20, 2016 | Televison & Video
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
Wat is sap? its benifits future prospects and from where to do its courses and their fee??
TEKSLATE is Proficient in SAP training which emphasize on hands on experience with examples from real-time scenarios by experts.Register Here and attend for FREE DEMO Please Contact: email : info@tekslate.com website: https://tekslate.com Live Online Training of HANA OBIEE Informatica and Oracle Courses
May 14, 2010 | Computers & Internet
Need the Authorization Code in six boxes
you need to coordinate that to adobe online support .
https://licensing.adobe.com/sap%28bD1lbiZjPTAwMw==%29/bc/bsp/sap/zavllogin/login.htm
Apr 22, 2010 | Adobe Flash® CS3 Professional Full Version...
HI, I took dell laptop with 500gb hard disk, 4 gb ram, i5 processor. they given operating system windows 7, but i want operating system windows 2003 to install SAP. Can i get write drivers for OS Windows...
That processor runs x86 code so yes it will work, with Win 2003, Have you thought about Vmware? or Virtual PC? you could install a virtual machine, install 2003, and also, SAP, then you could have best of both worlds. Otherwise just install Win2K3 no problems... You could even dual boot, if you wanted to.
Feb 26, 2010 | Computers & Internet
NO SOUND AUDIO
Just to be sure, it isn't on SAP is it?
That would be under the MTS/SAP button.
If that's not it, are there any other distinguishing features that you notice?- A buzzing or a clicking or peculiar light flashing?
I wouldn't be able to help with that, but the next person might!
May 08, 2009 | Sony KP-46WT520 46" Rear Projection...
Mono stereo sap on screen
you need to reset the preferences on you sound icon in the menu panel
Mar 26, 2009 | iLO 3200 32 in. LCD Television
Where i dounload the crystal report runtime for server 2003.
Go here and download what you need.
https://websmp130.sap-ag.de/sap(bD1lbiZjPTAwMQ==)/bc/bsp/spn/bobj_download/main.htm
Select the appropriate version of crystal reports you are using from the three combo boxes.
Jan 06, 2009 | Panram International Panram 256 MB USB...
Heating & Cooling Logo
18 people viewed this question
Top Sanyo Heating & Cooling Experts
Dennis Boxerman
Tim Whalen
Chuck
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
