Question about Garden
Stihl chainsaw starter rope stuck and won't pull?
5 Suggested Answers
SOURCE: Stihl 015 Chainsaw - Change Pull Start rope
You have 3 screws to take out. 1 by the trigger and 2 on the side cover ( one on top and 1 on bottom).
The first thing you want to do is remove spark plug. After plug is removed carefully separate the housing paying attention not to lose the little spring holding the trigger when it comes apart. You can do this with the bar/chain on, but easier to handle without it. After it comes apart you can remove spring clip holding flywheel on. Be careful to lift the flywheel straight up slowly making sure the coil spring does not come up with the flywheel. If you just move it back and forth a little while moving the flywheel off the shaft. Take the rope off and measure it. I think its about 18" but try to measure the one on there. Make sure you knot the rope leaving a small tail so when the knot is tightened it has a little room to move without coming undone.After you wind the rope (clockwise) leave about 1/2 '' of rope sticking up in the notch on side of reel . Slide the wheel down and make sure the bottom notch on wheel is going to engage the coil spring when the wheel is turned.Replace spring clip on the shaft. If you have a problem with the clip, you may not be down far enough with the wheel. Turn the wheel about 1 1/2 to 2 full turns putting tension on the spring and making sure the rope sticking up is close to the the hole you need to string it through to tie in the handle. After you feed the rope through the hole (making sure you are adding more pressure on the spring as you pull the rope out, enough rope to work comfortably with the handle I take a fat bladed screwdriver and stick it down in between the wheel and housing to stop it from unwinding. Then string it through the handle with the same kind of knot used for the flywheel. After your handle is secure you can remove the screw driver and see how it works before re-assembling. Putting the housing back together requires patience making sure the housing fits over the flywheel and trigger area goes together nice.
Tips: If you need aid in stringing the rope through the handle I take about 6" of electrical tape wrap it around the end of the rope about 5 times and make sure as you wind the tape is moving towards the end of the rope and you can have a tail off the end of the rope to send through the handle. Good Luck
Rob
Posted on Jun 11, 2009
dontbother10
  • 2220 Answers
SOURCE: starter rope will not pull. Will pull smoothly
If I understand what you are saying... The starter pulls smoothly with the starter cover removed or when installed and the plug removed (no compression or spark). If this is correct I think your saw's timing has slipped or maybe a defective decomp valve. Time to visit your neighborhood chainsaw seller/mechanic.HTH
Lou
Posted on Sep 17, 2009
Testimonial: "cheers"
  • 583 Answers
SOURCE: the starter rope doesnt pull, and when the saw is
sounds abit like it ,but remove the spark plug and you should be able to rock the flywheel back and forth. sounds a bit like no oil in the gas or at least insuficient oil and may have grabbed, (i assume you have the chain and bar off the powerhead,if not then remove them ,and then try ) it could also be the centrifgal clutch jammed up.
Posted on Dec 29, 2009
SOURCE: i am trying to install
Hi this is how I did my spring on the my stihl 017 this work for me.
rewind a un coiled pullstart spring
Good luck. Steve
http://www.youtube.com/watch?v=qTcL3_3leTk
Posted on Jan 11, 2013
Clutch bearing seems to be sticking
sounds like its on its way to seizing up, either damaged bearing or piston
Jan 17, 2016 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Stihl 310 worked last week, now it wont start
Could be lots of things. Check your spark plug that it fires when pulling the starter rope, old fuel, blockage in fuel system, maybe carburetor needs to be serviced and membrane replaced, cut out switch faulty.
Sep 27, 2014 | Stihl Oregon 31-099, Pulley, Starter For...
Chainsaw troubleshooting
Sounds like the engine decompressor is stuck shut remove it clean up with carb cleaner and try again.
Jul 04, 2014 | Stihl 009l
The rope broke when I tried to start the chainsaw. How do I replace it?
Your rewind spring is now sprung. Remove recoil assy ( the part your rope slides into). Remove all old rope remnants and rewind the spring. Install new rope, tie it off and slowly release spring rewinding the rope.
Mar 14, 2014 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
How to wind clockspring on a pull rope ms 180 stihl chainsaw
Go to Youtube and watch a video on how to repair a starter .
Dec 02, 2013 | Stihl Garden
Installing a spring in an MS240 Stihl chain saw
I have not worked on you type saw. I have put new starter springs in other saws. One end of the spring fits into the housing and the other in the pulley. Once you have that done there should be a notch in the pulley that you put the rope into that will allow the spring to be wound up without taking up the rope. It is a trial error problem now. If the spring is wound too tight you will not get full rope travel. If it is too loose tilt will not pull the rope in fully.
Jun 01, 2013 | nwp Starter Recoil Spring Fits Stihl 024...
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
Black arms in clutch dont allways come out and catch when rope pulled. Chainsaw rope pulls out without catching and turning over to start. What should i do?
Most Stihl starters that i have seen rely on the r clip securing the pulley on being a tight fit on the shaft, this creates a friction, as the pulley turns the clip trys to stay still and in turn pushes the pawls out, remove the clip and squash it close together to create a better fit on the shaft
Jul 09, 2011 | Stihl Chainsaw 045 056 Clutch Chain Saw...
The starter rope doesnt pull, and when the saw is
Dec 29, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
