Question about Gaiam Walking Fit Kit Pedometer Advanced
How do i turn it on
Don't know how to turn it on
C9 champion digital alarm
Since you don\'t know how to turn it off, the alarm will give you simple instructions. Just stop pressing the buttons. Is there a symbol or an alarm or clock on any of the buttons?
May 10, 2013 | Watches
Voice Over is on. I have an iPhone 4. I don't know how it even got turned on but don't know how to turn it off. Is there something in the settings??
in the home screen double tap settings and scroll using three fingers and double tap general again scroll using three fingers double tap on accessibility and double tap voice over and double tap it to switch off
Mar 23, 2013 | Apple iPhone4 4G iPhone 4
I want to turn the automatic flash off my samsung ES17 camera but don't know how. I was told to turn off auto mode but don't know how to do that either. Lost the manual. Can you help please? Many...
You can download the manual at website below to solve your problem. it is free.
http://camera.manualsonline.com/manuals/mfg/samsung/es17.html
Regards
Sep 10, 2011 | Samsung Es17 Digital Camera
My camera fell in the sand I don't know if the sand got stuck in it & I don't know if that is what is causing the problem with the lenses not opening
is it notifieing you that there is a lens eror? or does it just not turn on? This type of problem you won't be able to fix yourself, and don't try to either! You will need to contact Kodak and tell them there is a lens eror (don't give details that you shouldn't be giving), hopefully they will be willing to fix it for you or replace with refurb.
Aug 30, 2011 | Kodak EasyShare M1093 IS Digital Camera
My turning signal don't work but the flashers do work. I have changed all fuses and they still don't work.
since you know where the fuses are, you also know where the flashers are. the flashers are the same part so unplug the one for the emergency flasher and put it into the socket for the turn signals and vice versa. if the signals now work but not the emergency flasher you know to get a new flasher unit at any parts store. the flasher units are cubes about an inch on each side plugged into the fuse panel.
Jun 27, 2011 | 1995 Chevrolet Caprice Classic
I have a raindrip 2 zone water timer...I don't know how to set it. There is no clock set, so I don't know how to program it to turn on at a certain time...
You can download your instructions here:
R673CT Digital Water Timer Installation Manual
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Raindrip R673CT Digital Water Timer
Hi Don't know how to turn on answering
On the base set, with the phone in standby mode, press the [ANSWER ON/OFF] button. If it's not in the state you want, press it again to change.
May 11, 2011 | Uniden DECT15802 Twin Cordless Phone
Gaiam Walking Fit Kit Pedometer Advanced Logo
32 people viewed this question
Top Gaiam Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Gaiam Exercise and Fitnes Expert? Answer questions, earn points and help others
