Question about Samsung Refrigerators
Smoke coming out of samsung freezer - Samsung Refrigerators
Smoke from microwave
Is there not mentioning from were the smoke comes.is the smoke comes from inside where we coocking, check the inside areas .is there any dust or dirty inside. Or the smoke comes from inside the where the components fixed.check the air circulation blower.or the capacitor and the diode assembly may burned.
Mar 05, 2014 | Kitchen Appliances - Others
When I preheat my samsung Microwave oven, smoke is seen coming out. is that Normal?
Not really, some smoke is sign that some component inside is NOT o.k you must open the microwave and see what going ON. and fix it.
God bless you
Dec 09, 2013 | Samsung Microwave Ovens
Smoke coming back
The main dc reservoir in the power supply must have burst. This capacitor 47 to 100 MF/400V also releases lot of smoke when it bursts. Most of the times you just have to replace it and the tv works fine.
Aug 23, 2013 | Samsung LN32A330 32 in. LCD TV
Smoke is coming out of the a/c
Ice probably formed on the outside of the unit and the a/c is working to defrost itself. Check out this page: http://andysair.blogspot.com/2010/01/looks-like-smoke-is-coming-out-of-my.html
Jul 08, 2010 | Sharp AFS60NX Thru-Wall/Window Air...
I have smoke coming out of the freezer fan grill and water dripping outside on each side of the shell between the freezer and refrigerator. What is the problem?
Your drain may be plugged and water is getting onto the fan's electrical.
Go to back of the unit, remove access panel, check that the little drain tube is dripping water into the evap tray. Tray should be somewhat wet. You can use pipecleaner or coathanger to check for clogs in drain. Or cut the bottom rubber piece off to allow better flow..
Nov 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
SMOKE COMING FROM BACK OF FREEZER
Hi jimali1987,
I'm Harvey the Master Plumber.
Your problem is: Smoke is coming from lower rear of unit.
Unplug! Remember where there's smoke there's fire. Get access to compressor and find the burnt wire or whatever it was. I have found burnt animal nest in the past. You never know.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Whirlpool Refrigerators
Malfunctioning American Fridge Freezer
Is it freezing. Sometimes those led's go out.
Dec 21, 2007 | Freezers
Air Conditioner Smoke
The smoke you are seeing is the cold air turning the hot humid air into a cool mist. This may happen when you first run the a/c to cool the room. Once the room is cooled down you should not see the mist any more.
Jul 09, 2007 | Maytag M3V08S2A Air Conditioner
Refrigerators Logo
14 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
