Question about Ricoh Aficio CL3500N Laser Printer
Feeds several sheets every print job - Ricoh Aficio CL3500N Laser Printer
  • Ricoh Expert
  • 398 Answers
There shoud be a paper feed kit, but here are the Ricoh part # seperatly
G0812474 Sep pad, ( make sure this pad is spring loaded to push up) If it feeds but grabs more than 1 sheet this is your problem. if the spring is missing the p/n is G0812475.
-Carl
Posted on Jun 28, 2009
Feed tires need to be replaced
Posted on Jun 18, 2009
Printing 12 x 18 from tray 4 Every 2nd sheet jams.
MAKE SURE YOU SET THE THICKNESS SETTINGS AND OTHER SETTINGS ARE CORRECT, MAKE SURE IT IS 12 X 18, CLEAN THE FEED TIRES WITH WD 40 THEN RUBBING ALCOHOL, MAKE SURE ITS DRY BEFORE FEEDING PAPER
IF YOU HAVE A TRAY 5, ITS MORE RELIABLE
IF STILL PROBLEM HAVE YOUR TECK USE THESE PARTS
A03X565300 FEED AND TAKE UP ROLLERS
A03X565400 SEP ROLLER
56AA82012 BOTH CLUTCHES
AND TRY UNPLUGING TAKE UP ROLLER PICK UP SOLIENOID, WELL IT SHOULD WORK BETTER, AND MAKE SURE YOU DO THE BOTH SIDE ADJUSTMENT, WITH OUT SEEING EXACTLY WHAT THE COPIER IS DOING THIS IS MY BEST ANSWER
Aug 24, 2013 | Konica Minolta Bizhub C5500 C6500 C5501...
Every 10 prints or so a single sheet of paper will come out printed but will crunch up as it is feeding to the output tray. Nothing seems to be blocking it because not every page does it.
If you are getting blank pages between print jobs or between page or each print job, separator sheet must be turn off. By default NONE is the factory settings for separator sheet. You may restore factory defaults. to do this click on menu>settings>general setting>factory defaults.
For further assistance, please contact Lexmark Technical Support
Mar 08, 2011 | Lexmark C540N PROD SPECS TBD Printer
Printer won't print documents. Green light on
Hmmm, try feeding a sheet of paper into the manual feed slot... you might have inadvertantly sent a Manual feed job, and the printer is waiting for a sheet to be fed by you.
Feb 10, 2010 | Dell 1710n Laser Printer
I have a Canon MP470 that pulls 1/2 sheet paper and then jams
Paper feed roller
cleaning
When paper does not feed
properly.
To clean the paper feed
Machine button
Oct 07, 2009 | Canon PIXMA MP470 All-in-One Printer
When I print on my Canon MP730, it always prints out a blank page after every print job. How can I fix this?
SOLUTION(S): Reset the Sheet Feeder Gears
If the power fails while the paper is feeding or during a print job, the paper feed gears will lose their proper
alignment. The reason is that after the power is restored the paper feed gears will attempt to return to the
home position, which may not be possible if the paper stop cam is not in the correct position.
PROCEDURES
1. Remove the sheet feeder from the unit.
2. Remove the sheet feeder motor from the sheet feeder assembly.
3. Remove the drive gear from its spindle.
4. Realign the lifting tray gear and paper stop cam gear.
5. Reinstall the drive gear and sheet feeder motor.
6. Reattach the sheet feeder to the print unit.
7. Reassemble the unit.
Jan 11, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
HP PSC 1315 Problem
Glad to know that your problem is solved.
Thank you for using fixya..
Jun 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Printer feeds through blank piece of A4 fast, followed by another one, slowly
Service error 6A00 Cancel printing and turn the printer off and then back on.
If this doesn’t clear the error, see the printer manual for more detail.
Jun 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No paper
Tracoi, first you need to clear pending prints. If your using WinXP, click the start button slide up to & left click on Printer and Faxes. Click on your printer & clear/end prints pending. Power off your printer & look in the printer where the paper path is. As the paper passes through the printer, it pushes against little black sticks that wobble back and forth to trip the different sensors. These little 'flags' usually kind of stick up in the middle of the plastic along the paper path. Look over the whole paper path and find all the little flags and make sure they're all moving freely. Sometime they get knocked out of place. You only need one to mess up the printer function.
Luck!
If this did not help just let me know & we'll try something else.
Mike
Apr 19, 2008 | Samsung SCX-4100 All-In-One Laser Printer
Check paper light blinking and "E" code
trying to print the las job you had.
Try hiiting the cancel button when you turn it on
Oct 22, 2007 | HP PSC 1315 All-In-One InkJet Printer
Ricoh Aficio CL3500N Laser Printer Logo
69 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
