Lid on top loading washer frigidaire won't stay up
catriver
  • 878 Answers
SOURCE: replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Posted on Apr 15, 2007
  • 156 Answers
SOURCE: leaking frigidaire top load washer
yes there a seal under the tub ring make sure tub ring has all the snaps in place
Posted on Mar 03, 2008
  • 1073 Answers
SOURCE: Frigidaire Washer machine with burning smell
burnt belt, tight center tub bearing, motor going bad, loose idler pulley spring, wiring issues at the motor, a lot of could bees
Posted on Apr 12, 2008
huuum
  • 750 Answers
SOURCE: need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Posted on Oct 08, 2008
fernie_elazt
SOURCE: My Frigidaire gallery front load washer won't spin or drain
its ether the transmission or the motor gone bad
Posted on Jun 29, 2012
I have a Frigidaire affinity top load washer and the lid wont stay up!!! How do I fix this?
Good Morning Shawna Midkiff, thank you for your post!
From my understanding the lid for your Frigidaire top load washer is not remaining up. It sounds like you could have a possible issue with the hinges. I would consult with a professional technician to have them come out to accurately diagnosis and repair your washer. Hope this helps. -Matt
Oct 16, 2014 | Frigidaire Washing Machines
Will not drain
FRIGIDAIRE TOP LOAD WASHERS WILL NOT SPIN OUT WHEN THE LID LOCK IS BROKEN
Mar 20, 2014 | Frigidaire FWS833A Top Load Washer
Frigidaire washer recall
You should contact the company. My washer had a part recalled, which was causing it to throw error codes our all the time. Luckily it was still within the warranty so a replacement part was sent right away. Good luck
Jan 03, 2014 | Washing Machines
Frigidaire top load washer lid will not stay in open position.
front of washer legs are to High or back legs to low level machine or change door hinge
Aug 13, 2013 | Frigidaire Affinity ATF7000E Front Load...
Why is my frigidaire washer not spinning?
  1. Stopped Mid-cycle
    • If your Frigidaire washing machine started spinning, but then stopped, verify that the power cord is still connected to the outlet. See if the outlet blew by plugging in a different appliance into the outlet. See if you blew a fuse. A blown fuse usually is either black or has broken wires. Replace the fuse. If you have a circuit breaker instead of a fuse box, reset the circuit breaker if it's been tripped. Check the lid switch, which is located inside the main housing of the washing machine, near the door frame. If the switch is burned out, order a new part from a Frigidaire parts dealer.
    Pump
    • The pump's sole responsibility is to remove water during the spin cycle. If the pump isn't working properly, see if it's clogged with debris or clothing. Use needle-nose pliers to remove these items. Check the pump pulley, which is connected to the pump. This component must move freely for the pump to work. If it won't turn, purchase a new pump pulley since you can't usually fix this component.
    Lid
    • Check the door latch assembly if the door isn't closing correctly. If any of these components are broken, order a new part from a Frigidaire parts dealer. If you do not, the washer won't start spinning since it believes the door isn't closed. Your Frigidaire washing machine won't start the spin cycle until the lid or door is closed. Always close the lid, and remove any items preventing the lid from fully closing. Always close the dispenser drawer.
    Additional Concerns
    • Never over- or under-load your washing machine. Your Frigidaire washer may not enter the spin cycle if the load is too large, since this can damage the washing machine. Remove a few pieces of clothing. If the load is too small, add a few similar items to the washing machine. Check the internal belt, drive motor and motor coupling. If any of these components are broken or very worn, they may not work properly, preventing the washer from entering the spin cycle. Order replacement parts from a parts dealer. Check the tub and basket bearings, and get new ones if the current ones have broken components or are defective.
Sep 27, 2011 | Washing Machines
Top load washer - won't spin - how so i get the back off to check the belt?
If this is a frigidaire.there are two clips about one inch in from either side of the machine in the front that you need to push in with a flat tip screw driver to loosen the lid.then there are two screws down on the bottom front that need to come off,then the front panel will come off to access the belt
Sep 13, 2011 | Frigidaire GLWS1349A Top Load Washer
My frigidaire top load washer would wash but do not drain or spin.
You will need a lid switch if striker is good. Check your lid switch striker to make sure its not broke( thats the white plastic piece on the lid) good luck thanks for voting......
Mar 20, 2011 | Frigidaire FWS933F Top Load Washer
The locked light stays on but the top load door is not locked, and the washer will not start. I have unplugged the washer but still the cycle will not start.
What is your model type a FAV6800A or FAV9800A?
Are you up to troubleshooting the issue? We would need to see if the Left or Right hand lid lock is signaling the Control Board incorrectly. This could involve using a DVM to measure +12 VDC signaling from the Lid Locks to the Control Board.
A power Cycle of the Control Board won
Feb 14, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Frigidair top load washer Model fwx233res7 not spinning
If the motor is not running, then it sounds like the lid switch. If the motor is running, the belt could be the problem.
Jan 07, 2010 | Frigidaire GLWS1339AS Top-Load Washer
My frigidaire top load washer will not spin-out
Unplug remove cover and see if the lid lock is melting or damaged. Let me know what you find,Thanks, Sea Breeze
Mar 21, 2009 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
