Question about Bunn My Cafe MCU Brewer
Puddle of water under my bunn my cafe mcu - Bunn My Cafe MCU Brewer
3 Suggested Answers
  • 189 Answers
SOURCE: my Bunn coffee pot leaks water theres always a
It sounds like you have a broken seal/gasket. Please get the model and date code located on the bottom of the machine and call customer service. The machine has a 3 year warranty so if it is 3 years old or less, it will be replaced at no cost. If it is over 3 years old, it will be replaced at a discounted price.
Posted on May 19, 2010
MotoGenius
  • 3100 Answers
Mobile Phone and accessories
    Verified Fixya Pro
    SOURCE: Bunn Coffee Pot Leaks Water
    Or call bunn to get it for free due to recall
    Posted on Oct 31, 2012
    I just plugged in and put water in the top resevoir of my Bunn coffee maker, Model MCU. The The red square is flashing. How long does it take until it is green and ready to brew?
    Should be about 8-15 mins depending how cold the water was. Here are the instructions: Aloha! ukeboy57
    http://www.bunn.com/sites/default/files/care-and-cleaning/43460_0002d_mycafe_use_care_manual_english_0.pdf
    Feb 04, 2017 | Bunn Coffee Makers & Espresso Machines
    My bunn cafe red light flashes does not take water to tank nnot heating either. why?
    my bunn has 2 switches one on the left side to keep it HOT and the front one when brewed to keep it hot . the side switch if off will not heat the water and will not let the front heater be turned on either which is lighted
    Dec 14, 2015 | Bunn My Cafe MCU Universal 4-in-1 Single...
    Won't shut off after making a cup
    It sounds like the thermostat or Element is failing and causing your unit to overheat and boil. Probably time to call Bunn and see if your unit is under warrenty.
    May 03, 2014 | Bunn My Cafe MCP
    How do i clean my cafe before first time use.
    Add about a half cup of white vinegar to the water an run it through
    the maker about three times.After that use fresh water about three times. should be cleaned out .
    Apr 15, 2014 | Bunn My Cafe MCP
    BUNN MY CAFE BAD TAST WITH COFFE OR HOT COCO
    Try really cleaning the basket that the water and coffee or cocao goes into. If you don't really clean it well, it will have the taste of the last thing brewed mixed in with the new brew. Coffee followed by coffee should not be a problem, but coffee followed by cocao will give the cocao a coffee taste, and visa versa.
    Nov 21, 2013 | Bunn My Cafe MCU Universal 4-in-1 Single...
    My bunn coffee maker is making loud noises when it heats, I know it needs cleaning but I lost the book that tells me what to put into it. I did it once and it was quiet. I can't find that book now. Thank...
    The noise can occur when there is a heavy buildup of calcium on the heater coil. This causes the coil to get much hotter since the layer of calcium acts as an insulator and the water may come to a boil because the coil rises to a high temperature trying to heat the water.
    Unless it is too clogged, this may help; empty the water out completely, then put two cups of regular vinegar in the water chamber and turn on the power for a half-minute or until liquid appears in the pot.
    Let it sit overnight and then let the remaining vinegar pump through. You will have to run several pots of water through the machine or have some really strange-tasting coffee.
    There are commercial products that act more quickly and thoroughly than vinegar but also much more caustic.
    Nov 18, 2009 | Bunn Coffee Makers & Espresso Machines
    My Bunn coffee pot leaks water theres always a puddle of water under the pot.coffee pot is over half full
    Sep 13, 2009 | Bunn NHB Coffee Maker
    I obtained Bunn washer seal repair kit from buy-it-now-store.com for $6 plus $7 S&H and it solved the problem.
    Mar 06, 2009 | Bunn NHB Coffee Maker
    Bunn My Cafe MCU Brewer Logo
    178 people viewed this question
    Top Bunn Electronics - Others Experts
    Are you a Bunn Electronics - Other Expert? Answer questions, earn points and help others
