Question about Janome MyLock 204D Serger NEW MyLock 204D Serger
Serger Feed Dogs are working backwards
Janome MyLock 434D Serger is not working properly because the feed dogs are pushing the fabric away - toward the operator. They should be pulling it the other way. The lever on the left side of the machine seems to correct the direction but doesn't stay in position by itself.
  • Janome Master
  • 1,388 Answers
I have a Janome 1017 can I lower the feed dog for freestyle embroidery?
According to this, your machine does not have that capability:
Janome 1017 Review
HOWEVER, when a machine's feed dogs do not drop, there is usually an accessory included with the machine that is a plate that covers the feed dogs so you can sew without the feed dogs moving your fabric.
Your owner's manual is probably the best source for this information.
Jun 07, 2018 | Janome Sewing Machines
Hi, Janome 124 - top thread picks up the bobbin thread, motor sounds good. Th feed dogs won't pull fabric (or paper) thru the machine - dogs don't stick up much above the plate. Help please! Jan
Remove the needle plate and clean the feed dogs with a brush...remove any lint and bits of thread.
A couple of drops of sewing machine oil might help to loosen the feed dogs up. (maybe let the oil seep in and then turn the handwheel towards yourself to help things along.
One other thought:
If your machine has feed dog lowering capability you might want to move that lever/switch back and forth a couple of times.
The feed dogs might not appear to raise or lower, but some machines will only re-engage raised feed dogs when the machine starts to stitch.
Also...verify that the presser foot tension isn't too strong/heavy...and temporarily try using a longer stitch length setting.
Mar 19, 2017 | Janome Sewing Machines
Janome Machine will not feed material !!
If the fabric is not feeding, the feed dogs are probably not operating properly. Check that they have not been dropped below the needle plate (which is done when darning or free motion quilting). In this setting, the feed dogs never rise above the needle plate to grab and pull the fabric.
The other issue could be that the feed dogs are defective or perhaps seized.
Since you did not provide a model, I can provide only this assistance. It would be helpful to locate (search for make model manual) for your machine.
Dec 30, 2016 | Janome Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
Feed dogs don't seem to be working right.
the feed dogs could be broken or the lever that raises the feed dog could be broken, needs to be serviced
Sep 22, 2015 | Janome HD3000 Heavy Duty Mechanical...
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Janome MyLock 204D Serger NEW MyLock 204D Serger Logo
180 people viewed this question
Top Janome Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Carolyn Rogers
Carolyn Rogers
saskeet
Level 1 Expert
Are you a Janome Craft and Hobby Expert? Answer questions, earn points and help others
