Question about Ruud Heating & Cooling
Only getting hot water in certian areas - Ruud Heating & Cooling
    Novelist:
  • 189 Answers
Purge all air out of the system. Check all of your zone controls.
Posted on Sep 13, 2014
No hot water
This indicates a reduced supply of water to the heater. Check water flow through the tap has not been reduced If so, check filter area
Apr 17, 2014 | Takagi T K3 OS P OnDemand WaterHeat
There is a leak and we can not find it. Any solutions
This may help?
Fill spa to highest level possible.
Heat to 100 degrees or higher.
Then, with your bare hand feel throughout the bottom rim and anywhere else you are able to: see if you can feel "Warm/Hot" water. Any "Cold" water is not the area of the leak, that water has "Travelled" there. The warmer the water, the closer you are to the origin.
Jan 01, 2014 | Eclipse 4 Person Hot Tub Spa - Dream Maker...
Heater gets hot but then blows cold air have replaced the thermostat gets hot for awhile then blows cold air
Sounds like a bimetal over temp cutout is faulty.Usually about 30mmx20mm in size with 2 wires.Cuts out when heater exceeds a certian temp.
Oct 16, 2012 | MTX ThunderForms 2001-2003 Ford F-150...
Sun blotches in areas,seems like color is fading.CERTIAN AREAS
Do you wash it with detergent soap? Detergents take the oils out of the paint and causes fading.
Aug 06, 2012 | 1996 Ford Mustang
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
Bad water supply to hot tap and a banging noise when you turn the tap off
No charge for this one.
Educated guess but are you in an area where you have water scale. That is a lime build up especially in hot water appliances as the scale forms on hot surfaces. This would reduce the flow of water through to the hot taps and cause what we call kettling which accounts for the noise. Maybe give a local plumber a ring and ask about scale in your area. Other than that not too much info from you to suggest anything else. Please get make and model of hot water system and re-post problem.
Dec 07, 2010 | Water Heaters
I just bought a repo house which has a grundfos circulation pump u p 15 installed at the water heater. House built 2005 4260 sq. Feet. House has 4 showers only one of them gets hot water. All sinks get hot...
that pump is likely to be a hot water return pump not a booster pump. it sound like a large property so its likely the hot water system requires balancing to get the hot water to the extreme areas. If all the hot outlets have some form of isolation valve try closing all but the affected areas and see if hot water comes out. If so only open the closed outlets enough to give you reasonable flow. This hopefully will force the hot water to the affected areas.
May 20, 2010 | Home
The dishwasher gets stuck at a certian point during the cycle. How do I fix this
It's possible your water is not hot enough, and the washer goes into a pause heat mode. There also could be a problem with the heating element in the d/w.
Jan 02, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
WHEN MY WATER TANK IS COLD AND I TURN ON THE HOT WATER TAP THE WATER FLOWS FREELY BUT IF I HAVE THE ECONOMY 7 ON OVER NIGHT THE TANK GETS HOT BUT NO WATER FLOWS OUT OF THE TAPS. I LIVE IN A HARD WATER AREA
You may need to replace the tap.hot water is causing the valve to expand and yours may be using a rubber seal inside which is causing expansion and hence no hot water is allowed through it..Trust me on that..
Aug 27, 2009 | Water Heaters
Roper washing machine fail to remove enough water from clothes on spin
I had the same problem, I found that my discharge hose was partially plugged and when the water level get down to a certian point it would not drain,
Took me 3 days to figure it out........
Feb 19, 2009 | Roper RAS6233KQ Top Load Washer
Heating & Cooling Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
