Question about Whirlpool Dryers
Whirlpool dryer panel turns on but won't start dryer, hear click
I have a whirlpool electric dryer (model #: YWED9151YW0 Type: CHZN-ELE-2406024-EL54) that I bought from Sears Canada, that has been fixed several times during the 2 years. The dryer was only bought brand new in Sept 2012. We have had the thermal fuse replaced countless times, the front panel 3 times, the thermostat twice, and the motor once in the past 2 years. Getting it fixed averages out to about once ever 2 weeks. We never know when we'll be able to wash and dry all our clothes at the same time. To get a tech out to fix it always takes at least 2 weeks because the first visit is just to find out what parts they need to do the job. Enough is enough. What should the technicians be fixing and how do they fix it once and for all? I'm about ready to dismantle it myself and throw it in the dump. I'll never buy from Sears again and most definitely won't buy a Whirlpool dryer again. I used to like Whirlpool as everything else I have from Whirlpool works fine, including the matching washer.
    Novelist:
    Scholar:
  • 166 Answers
With a service record like that, I think a call to the Consumer Protection agency is in order. It's obviously a lemon. Or to put it another way, it's unsuited to the task it was designed for.
But here's a tip:
Major household appliances that rely on electronic or "touch" controls are notoriously troublesome - regardless of brand. Not because there's anything wrong with the concept, but because the implementation of the concept is flawed, with the overriding concern being cost. Those electronic control boards are designed right at the margin of reliability to start with, and then they're made in China using the cheapest components available, and produced using unskilled labor. They can be expected to fail early and often.
Fixing it yourself is not a solution because you're still stuck with the same low quality replacement parts as the originals you're replacing.
For your next machines, stick to the ones that use the good old fashioned mechanical timer knobs. They're cheaper to buy too, and not because the mechanical timers are cheaper, but because the electronic models have a (falsely) perceived added "value" to the buyer which artificially pumps the price.
Posted on Apr 15, 2014
maklean
  • 1665 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
docjohn174
  • 943 Answers
SOURCE: Whirlpool Dryer Help
Hi theres 2 things that can cause this #1 a dirty vent to the outside. #2 a dirty lint filer , Take the lint filter out & run hot water through it. If water wont flow through the screen, Its gummed up by Bounce sheet residue, Clean the filter . It should be ok
Posted on Jan 21, 2009
SOURCE: whirlpool duet front loader dryer....sensing light won;t shut off
I have a whirlpool electric dryer and it cuts off and shows E 1... What is the problem?
Posted on Apr 21, 2009
  • 121 Answers
SOURCE: Roper dryer stopped working during cycle REX6634RQO
replace your t-fuse again but also chekc to see if the vent going outside is restricted. if hte vent is smashed or clogged the heat has nowhere to go. i would say that is your issue. clean your vent before you change he t-fuse.
Posted on Oct 20, 2009
heatman101
  • 43501 Answers
SOURCE: i have a type DHZN-ELE-2406024-EL54 model
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on May 06, 2010
The clothing do not toss around the drum and the clothes come out in clumps and wrinkled
You may be over stuffing. Try smaller loads and see if you have better results. Too much stuff in the dryer means that your clothes will have less room to move around, and if they're all crumpled up in the machine, they'll come out, well, crumpled-up-looking.
Jun 13, 2016 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
When I was ready to press the On button on my dryer, I noticed the control panel locked light was lit. So I began to press any button, still nothing happened. Since this dryer was donated to me and my
Your model number does not appear to be a valid or complete number, there should be a key on the panel that shows a little lock, this key should be pressed for about 3 or 4 seconds till the lock indicator goes out. Pleazer Appliance...
Dec 16, 2014 | Whirlpool Dryers
My dryer is a kenmore elite HE3 model number DADT-ELE-2406024-EL54 and is making a loud noise at the bottom in from
Dec 01, 2014 | Kenmore Washing Machines
My kenmore elite he3 quit working model number DADT-ELE-2406024-EL54 do you know why?
The heating coil safety switch/fuse may have been activated if it got too hot in there. It is very common for escaped lint to finally build up where it should not be. The first thing is to learn how to remove the front of the machine and inspect for a build up of lint. Happens often over time.
Nov 05, 2014 | Kenmore Dryers
What is wrong with my Kenmore Elite Quiet Pak 4 HE3 Electric Dryer?
Might be a2 things: Vent blockage causing overheat OR bad thermistor. Repair clinic shows how to replace it:
PART AND VIDEO
Note: Make sure you order the correct thermistor for your dryer
Dec 05, 2012 | Dryers
Hello I need info how to install a clothes dryer in Argentina
I think it should be ok as it is.it sounds like takes both 120/208v and 120/240v..you may just need an adaptor to fit different powerpoint pattern.??
May 28, 2010 | Dryers
I have a type DHZN-ELE-2406024-EL54 model
heatman101
May 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
Dryers Logo
125 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
