Question about Cub Cadet Garden
Trying to start.no gas going motor.m60 tank by cud cadet.
No gas getting to motor.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Check to see if fuel pumpis working
Posted on Dec 17, 2014
3 Suggested Answers
jasonamoss
  • 77 Answers
SOURCE: cub cadet 1042 wuth 42
There are just so many possibilities. I doubt this is specific to Cub cadet. Usually it is a result of a misalignment.
You can go here for some more information
Lawn Mower quality of cut
Posted on Jan 14, 2010
charlesbe45730
  • 1917 Answers
get to someplace level measure deck height from grond if all same then your tire is low air it up
Posted on Jul 19, 2014
Cub cadet M60 tank cuts fine for a while, but blades slow down and engine Boggs down after 20-30 minutes of cutting.
Maybe it is getting clogged up, clean out the area under the mower deck and check for worn and binding parts, something is putting a large load on the engine to cause the loss of RPM's
Aug 22, 2017 | Garden
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
Is there a way to test a fuel pump on a Cub Cadet M60-KH (53BB5BDX750)
Those pumps are cheap enough on ebay. Take yours apart and clean the diaphram and the valves to make it work better.
Aug 19, 2014 | Cub Cadet Garden
Kohler engine command pro 27 hp not start cub cadet m60 tank
spray some starting fluid in carb if starts ether bad feul filter or fuel pump or need to rebuild carb
Jul 23, 2014 | Cub Cadet Garden
Need valve adjustment specs for 25 hp kawasaki
sometimes it is better to have more clearance than not enough
Jun 16, 2013 | Cub Cadet Tank Riding Mower M60-KW-LC
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
69 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
