Question about Bosch AQUATAK 115 PLUS Pressure Washer
Motor smokes When I started the pressure washer up smoke came from it
Samsung front loading washer started smoking while on spin cycle , new rubber seal an bearing ?
my first though would be to consider if its electrical smoke of friction smoke, chances are if it smokes on spin the motor is over heating and ready to pack in its operation, new brushes may solve the problem before buying a complete new motor.
Sep 21, 2016 | Samsung Washing Machines
Honda pressure washer GCV160 5.5 HP started smoking while engine was running.
White smoke or black? White means the carburetor is flooding. Black smoke could mean a clogged air filter.
Sep 16, 2013 | Garden
Craftsman 19.2 v cordless drill smoking..what do i need to replace
You need to replace the whole unit. A motor which smokes when you are using it means the motor is burnt out or you are putting too much pressure on it making it work too hard. I have a feeling it's burnt out. I don't think you can repair it.
Mar 17, 2013 | Craftsman C3 19.2 Volt 5 1/2" Cordless...
Started smoking, but good water pressure
This certainly is a fault in the electric motor. Try the machine without load. That is...remove gun completely.
If smoke still appears....windings in electrical motor are damaged.
Myself I prefer to change motor than to rewind. More than that...safety is my policy. If in doubt and you see it is going to get expensive, consider a new machine. If possible the same model if you agree. In this way you can turn to your old machine for certain spares.
Thanks,
Fulltech.
May 05, 2012 | Karcher K3.68MR Electric Pressure Washer
After I start the pressure washer,do i push the choke back in,or leave it on?because it was smoking a little bit when it was on and running.or is that normal?
You turn it off after is warmed up, if it is smoking some , depending how bad it is won't hurt, unless it is running rough or smokes bad. Then needs possibly light tune up. You know oil change, fuel filter, clean air filter.
Jun 09, 2011 | Garden
Gas mixing with oil even while motor is running. whats causing this?
if its smoking alot oil ring on piston stuck in oil passing the piston engine will smoke
Feb 11, 2011 | Karcher 2500 PSI Pressure Washer
Karcher 2400 psi with honda motor started up big puff of white smoke from exaust it shut off noiw wont start whats going on
I have a john deere 3000psi pressure washer with similar problem. Running fine then a puff of smoke and it shut down. I checked the oil and found it full of water. Not only that but since I still had the water turned on, the water was flowing out of the dip stick tube. I'm trying to find a solution online and will pass any information on.
Nov 13, 2010 | Karcher 2500 PSI Pressure Washer
Karcher k 2.36 smoking and flashes of light inside the machine.
Hi:
This sounds like a short circuit or motor problem. They are relatively easy to take apart. If you see a burned wire or connector this can be repaired. If not, it is the motor and probably too expensive to repair considering the price of a new one.
Jun 30, 2009 | Karcher K2.26 Electric Power Washer
Bosch AQUATAK 115 PLUS Pressure Washer Logo
48 people viewed this question
Top Bosch Garden Experts
roeb
cwradio73
Are you a Bosch Garden Expert? Answer questions, earn points and help others
