Question about Citizen CI-1000SQe Matrix Printer
Citizen CI-1000SQE Faded print
I am getting faded print on one side. Eliminated ribbon already. Any ideas on how to darken print would be appreciated. Thanks
0 characters
1 Points
Yellow ink faded on one side of copy
Ink News - How To Correct Faded Prints From Toner ...
Rating: 3 - ‎12 votes
Mar 30, 2012 - You should particularly suspect this if the prints are faded on only one side and if the printer is not telling you to replace the toner cartridge.Missing: yellow
HP Officejet 6500 Printers - Fixing Print Quality Problems ...
Jan 16, 2016 | Printers & Copiers
Faded print on right side of page. When I copy/print in black, why is the black print faded on the right side of the paper?
Your toner cartridge may be the culprit.
Take the cartridge out and shake sideways and up/down. Reinstall it and try again.
If it's still printing faded side, replace the cartridge.
Jul 30, 2014 | Brother MFC-9840CDW Laser Printer
On the right hand side of the print head is a blue thumb wheel. ensure this is set position 9, this will give you full width print. This adjustment is for setting narrow width labels.
Jan 24, 2013 | Citizen CLP-621 Label Printer
Dell 1110 faded print left side
If you have trid a different toner cartridge, then I would first try a new drum (not sure if toner & drum are in same cartridge, some are so you will have to check that) If not that, then I would suggest the transfer roller bar would be my next suspect if the printer has a lot of copies done on it.
Jan 13, 2013 | Dell 1110 Laser Printer
My CP1515n colour laser is giving faded colours.The left side of the print is very faded whereas the rest of the print is slightly faded
There are two reasons for faded prints. Firstly, faded print could be due to exhausting toner.
If it you have faded prints even after replacing the toner cartridge or if your current cartridge has enough toner, it is most likely be due to dust/ toner dust accumulated at the laser reflecting mirrors inside the printers,
which partially blocks laser beams and requires cleaning/ servicing by a professional.
Hence, it is recommended that you get the printer checked/ serviced from authorized service center.
Hope it helps! Good Luck!
Feb 26, 2011 | HP LaserJet CP1515n Printer
Sir ihave printing problem when i print a page on the left side margin impression faded there is some faded portion of teflon roller crieate this problem please assist me how to solve this problem ...
sir ihave printing problem when i print a page on the left & right side margin impression faded please assist me how to solve this problem regards KULDEEP SINGH BISHT
Aug 09, 2010 | HP LaserJet 1020 Printer
Print quality: dark faded, but continuous
Open top cover and remove toner, shake toner cartridge and try a test print. IF image good then problem is low toner level in cartridge.
Apr 01, 2010 | HP LaserJet 4 plus Printer
Magicolor 2400W - Printing Problem
check the green levers at the top of the fuser unit that have envelope icons on them.  They reduce pressure on the fuser assembly for thick stock.  It is possible that one side is up the other down, causing uneven pressure across a page.
Jul 08, 2008 | Konica Minolta magicolor 2400 Laser...
Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Faded print on one side of page
I have a SCX-4100 Samsung, replaced the tonger cartridge, it was working fine for a few hundred sheets of printing, but after that, the left side of the page was printed very light, faded.
If I run the "Clean Drum", it will print a litter better, but still faded.
What can I do to correct this problem?
Thank you
Nov 24, 2007 | Samsung ML 1710 Laser Printer
Citizen CI-1000SQe Matrix Printer Logo
21 people viewed this question
Top Citizen Printers & Copiers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Citizen Printer and Copier Expert? Answer questions, earn points and help others
