Question about Watches
Instruction manual watch
What battery goes in a humvee field watch
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Just had a new battery installed in a fila wind master watch. the hr, min and sec hands are spinning and it goes through the start cycle. not able to stop this. also need instructions on how to set time....
Hi, According to your problem first make sure that the battery that you have changed is OK, or try another battery. Your watch need a factory reset. If normal factory reseting doesn't solve your problem then you have to repair the machine.
Jun 29, 2011 | Fila Watches
Light works but whole screen goes green. is this a
There is no design faults and no faulty lamps. Instead of lamp there is LED (light emitted diode), which is shining when the button is pressed. Click on my profile (escapement), then click on Tips and Tricks. There you will find link to RIP CURL watch manuals. If after following all instructions your watch still deliver same fault, visit your closest watch repair shop and ask to replace battery. Rate me, please..
Apr 01, 2010 | Ripcurl Watches
Just bought the Timex T5E291 marathon watch but cant set the time and date. Anyone got a solution
For setting instructions on all Timex watches go to Timex.com and download your manual.
Holding down the mode button will put you in set mode. You can then cycle through the fields and set the watch using the srt and rst buttons.
Sep 22, 2009 | Timex T5E291 Fullsize Digital Marathon...
I have gone through 3 different watches, 2 fossils and one Bulova. All of them would just stop after a couple of months. I would replace batteries, then they would stop again. Is there any truth to the...
This is not a myth, but reality. Every living thing has it's own electric field and so do the humans. The difference is in density of that field - some has stronger, some weaker. And this is the cause of fast battery discharge and mciromotor stoping. Very few people has this field so dense, that the battery driven watch stops as soon as this person touches the watch. Most common is the case when the wearer of the watch needs to replace watch battery very frequently,so, I suggest you are one of them.
Consider of buying an automatic mechanical watch (spring driven). These watches are more expensive then their battery driven counterparts, but they can last for generations if looked after.
Do not buy kinetic or solar powered watches as you will expierence the same struggle as with battery driven watch.
Rate me, please.
Mar 19, 2009 | Watches
Setting alarm for Luminox 1848 Field Alarm Chrono
Normal 0 Here is the watch movement manufactures instruction .pdf.
RONDA startech Cal. 5130.D
http://www.ronda.ch/pdf/ba5130.De.pdf
Feb 17, 2009 | Luminox Silver Series 42mm Watch - Black...
Second hand on my watch now goes in 5 second intervals
Check the instruction manual if you have one. Tag-Heuer watches move in 5 second intervals to let you know the battery needs replacing. A neat feature. Now you know that you have a real Tag!
Dec 30, 2008 | Tag Heuer Link Automatic Chronometer...
SOVIET MILITARY DIVERS WATCH 191 CHS
Humvee go to www.bulova.com at bottom right click on "about us" next page click on "sevice centre" enter your watch model in search box (top r/h)
Nov 05, 2008 | Bulova Watch
Chane the batteries
good day dear cherished customer.
my name is eltoyosi and am here to help you.
You an change the batteries of your field and stream wrist wach by going to the back and gently getting the flip covering the backside of the wrist watch and there you will see the battery which needs replacement, you know replace the old battery with a new one recommended for field and stream F116GWBS
thanks
hope to hear how it went.
Apr 11, 2008 | Field and Stream F116GWBS Wrist Watch
Field & Stream Mens Watch, F42GUBS
Take the watch to a jeweller. They should have all the batteries and seals and tools necessary for the job, and it rarely takes long or costs that much. you could probably manage yourself, but getting the seals especially is easiest through a jeweller anyway. Most likely reason for any watch to be not working is the battery, the next would be moisture inside - normally visible round the screen/face. always worth replacing the battery to see, unless the watch cost less than the battery, which it didn't. Hope this helps :)
Jan 25, 2007 | Field and Stream Magnum F42GUBS Wrist...
Watches Logo
20 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
