Question about Hardware & Accessories
How do you bypass paragon model #8145-20 defrost timer
2 Suggested Answers
SOURCE: Set defrost timer on Paragon Electric Defrost-O-Matic
the problem is not necessarily with the timer. it seems you have more than ample time and time allocations to perform a complete defrost. most walk ins should have roughly 25-40 minutes of defrost every 4 to 8 hours. if you defrost with a heating element, you may have a problem with the strength of the element,or the element may be pulled away from the coil. you could also have a problem with the defrost thermostat(allowing the defrost to terminate prematurely)
Posted on Jun 17, 2009
How to find
Add comment and describe timer in detail
Paragon 4000 series timer is replaced by Intermatic T100 series:
http://waterheatertimer.org/Buy-T100-series-timers.html
Paragon defrost timers are shown following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#defrost
Or choose Intermatic defrost timers:
http://waterheatertimer.org/Intermatic-Defrost-timers-and-manuals.html
Gene
j
May 16, 2014 | Paragon 4001-0G Defrost Timer
Defrost timer 8145-20 goes to defrost end fans go out end heather go in but compresor will not stop
Is this a hot gas bypass defroster with a switching valve? If so, the compressor should be on.
May 07, 2014 | Paragon 8145-20 Defrost Timer
Paragon Model 632-00 Manual
Copy following link:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#632
632-00 is 120Volt defrost timer. Electric heat defrosting with fan delay.
Hot connects to terminal 4
Neutral to terminal 6.
One wire from Fan, compressor, heater each connect to terminal 6, and other wire connects to one of the other terminals depending on electric heat, hot gas, or water spray defrost
Jun 24, 2013 | Paragon Hardware & Accessories
Model 4001-ov trips the circuit breaker.
Assuming you have Paragon 4001 40 amp 120Volt timer
By-pass the timer so only pool pump is connected to breaker.
To do this, move wire from terminal 2 and connect to terminal 1.
If breaker no longer trips, then replace timer with Intermatic T101
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T101
Crossover wiring: Paragon terminal 1 goes to Intermatic terminal 1.
Paragon terminal 2 to Intermatic terminal 2.
Paragon terminal 3 to Intermatic terminal A
If breaker keeps tripping after bypassing timer, then tighten wires on circuit breaker and test again.
If breaker keeps tripping, then move wires to another same-size breaker.
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Breakers trip when they sense overheating.
If motor is causing problem, you might need electrician to track down source of overheating.
Jun 19, 2012 | Paragon 4001-0G Defrost Timer
I WANT TO BYPASS THE DEFROST MODE IN MODEL 8145-20
Unsure what you are trying to do.
Open following link to see how this timer works and how to wire it.
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
If you want to by-pass defrost cycle, remove trippers from dial and timer will not enter defrost state.
Or remove wire that is connected to terminal 3.
Oct 07, 2011 | Paragon 8145-20 Defrost Timer
I am looking for a source to replace timer motors and silver contacts on a bunch of paragon 8025 24 hour timers.
According to e-mail I got from Paragon in Nov 2010, Paragon is no longer making timers and parts.
Except for defrost timers.
I don't know how narrow the Paragon defrost line has become, if they still making their commercial refrigeration timers, or if they're just making smaller refrigerator defrost timers.
Or if Paragon has parts for the 8025
http://www.uni-line.com/common/custserv.aspx
Jan 12, 2011 | Paragon 8025-00 Enclosed Indoor 24 Hour...
Hello I need to replace a paragon model 4003-0 can you tell me what is compatable to this model? thanks maury
As you probably know, Paragon is no longer making timers and parts except defrost timers.
4003-00 is not a defrost timer
4003-00 is DPST 120Volt timer 24-hour mechanical timer
Paragon timers and manuals
Intermatic cross reference shows that T-103 is replacement for 4003-00
http://www.intermatic.com/customer%20service/competitive%20cross%20reference.aspx
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
T-103 has 120Volt clock motor and can control 1 or 2 - 120V loads or 1 - 240Volt load
Dec 29, 2010 | Paragon GENERIC REPLACMENT MECHANISM 110V...
I need a three phase wiring diagram for 8145-20 model timer.
8145-20 240Volt Paragon timer is not 3-phase.
Clock motor is 240V.
You need a transformer to convert 3-phase to single phase 240V to operate timer.
Then timer outputs can control 3-phase power using 3-phase contactors
Contactor below is 3 phase with 240V coil
http://www.grainger.com/Grainger/DAYTON-Contactor-2UTP7?Pid=search
Defrost timer wiring diagrams show below:
Dec 21, 2010 | Paragon 8145-20 Defrost Timer
Hardware & Accessories Logo
46 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
