Question about ATT - Avaya - Lucent 8410D Avaya Lucent AT&T Black Display Phone
How do I cancel call forward lucent 8410d
Came back from lunch and calls to my phone going directly to voicemail.
Lucent partner 34D calls go directly to voicemail
Sounds like either you have do-not-disturb activated, or you have call-forward-all to voice mail set. You should have call-forward-no-answer turned on but it's easy to enter wrong code. Find a list of codes for your system and see if its one of those.
Apr 19, 2014 | Lucent Lands Phones
Toshiba DKT2010-sd calls no longer go to voicemail
go to the website http://www.telecom.toshiba.com/ go to the call forward settings in the book turn off Call forward All and turn on Call Forward NA (No Answer) by default it should go to the VM system. If it does not figure out what you dial in the keypad when you want VM to answer.
Nov 22, 2013 | Toshiba DKT-2010 Corded Phone
I need to know how to transfer a call into someone's voicemail on the Avaya 8410D.
hit the transfer button ,dial the extension of the other user and hit transfer again . or hit transfer and dial the voicemail extension and dial the voicemail extension of the other party and hit transfer
Apr 18, 2011 | Avaya Definity 8410D Phone
I need a user manual for my phone. Lucent 8410D
http://minerva.stkate.edu/internal/docroom_helpguide.nsf/files/8410/$file/8410D.pdf
or, Google for "lucent 8410D filetype:pdf" to find other similar manuals.
Mar 23, 2011 | Avaya Definity 8410D Corded Phone
How to forward a call to a virtual voicemail box
With the caller on the phone, press a "Voicemail Transfer" button, then the extension number and hangup.
OR
With the caller on, press FEATURE 14, then the extension number and hangup.
May 19, 2010 | AT&T Lucent MLS-12D Phone
Night button not working
Sounds like the voicemail either locked up or died. Try turning off/unplugging the phone system for about 10 seconds and see if it that takes care of it. If it fails then it might be time to get a new one.
Jun 18, 2008 | Lucent PARTNER18 Corded Phone
Voicemail Light Indicator
It's ok. I'll call my IT department to fix it. Thanks.
May 10, 2008 | Avaya Definity 8410D Corded Phone
How do you turn off phone forwarding? Somebody inadvertently has their phone forwarding to another extension. Lucent Partner 18d.
It depends on the kind of telphonesystem and the kind of forwarding.
Generally the procedure is #code# where code is
21 for call forwarding unconditional
61 for call forwarding on no reply
67 for call forwarding when busy
On most mobile operators you can do #002# or ##002# to take the all in one go.
On some fixed (analog/PSTN/ISDN) lines you can use #001# to take them all inone go.
Some PABXes(officephones) also have call forwarding on precense (lunch, meeting. etc) and this is often turned off with #23#
Apr 01, 2008 | Lands Phones
ATT - Avaya - Lucent 8410D Avaya Lucent AT&T Black Display Phone Logo
87 people viewed this question
Top ATT - Avaya - Lucent Lands Phones Experts
Computer Repairing
Computer Repairing
Are you an ATT - Avaya - Lucent Lands Phone Expert? Answer questions, earn points and help others
